Writing C Programs using Eclipse
amitabh262002
Member level 2
Member level 2
HI
please tell me the procedure and setting for C programming and debugger settings for Eclipse.
First of all, you must download the plugin for the C\C++ Eclipse programming
One of the first questions that should be asked is:
Are you using Eclipse to write code for the PC or a microcontroller?
What C compiler do you have or you would like to have install?
And if this setup is not for a PC, what type of programmer/debugger to you have?
Let me know I have some PDFs to help step you through the installation process.
