c++ syntax error help needed
HarshJain
Newbie
Newbie level 3
India
else if((RI >= 181) && (RI <= 210)){
        if((ICT1 = false) || ((ICT2 = false) || (ICT3 = false))){
        cout << "ICT \n";
        if(ICT1 = false){
            ICT1 = true;
            goto endICT;
        if(ICT2 = false){
            ICT2 = true;
            goto endICT;
        if(ICT3 = false){
            ICT3 = true;
            goto endICT;
            endICT:
Howdy! This is simply an aspect of my program, and this bit of code appears a few times, with different variables and other stuff. When I compile the code, I get "error C2143: Syntax Error : missing ';' before '}'" I'm new to all this coding, and would appreciate any help! Thanks for your time! Basically, a random number is chosen, and if it's within a range, it goes through this part. This range can only be chosen 3 times because then the first 'if' would not be true. Thanks for all your help so far! Also, the error is in the 'endICT:' line.
you see there are
5 times "{" and
4 times "}"
--> but the numbers have to match. Check your code.
I´m not familiar with C++ but I think
you have to use "==" instead of "=" within the IF command
Using "goto" isn´t good practice. But still it is allowed to be used and sometimes even useful.
--> read about "goto"
Klaus
