First of all thank you both very much (+1 BOTH!), special thanks goes to BradtheRad for the schematic drawing (even tho I'm not yet familiar with all the symbols nor the term "100K impedance", nor do I understand how a 10K resistor can provide variable voltage) I'll go back to Electronics for dummies and continue reeding bot capacitors
Also special thanks to FoxyRick fpr providing very useful links, I'll definitely use 'em just not now, I have gathered diagrams before without knowing what I do like: LM185IT-ADJ/NOPB or analogue thermometer etc. But this time I decided to try to understand a bit more electronics rather then just connect 'em.
So I bought Electronics for dummies and read 25% yesterday, so I felt a great urge today to put some of all that theory into practise, it was not to be.
Ohh, ic ic, now, there is no need for 2 regular and one variable as in my set-up, just make sure that the 10 or 11k after the potentiometer eats at least 6.5V.
Ohh that, I tought bot tht -->> tried to measure resistance, no luck -->> so I tought Ill try with 1/4W resistor and if it gets to hot I'll then try with ½W.
Once again thanks for everything(+1): drawings, schematics analysis (lol), therm explanation , noob tolerance, issue elumination, etc.. AND YOUR TIME AND EFFORT, my deepest gratitude
