robotico
Newbie level 2
- Joined
- Aug 19, 2012
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Flyover state
- Activity points
- 1,294
Hi All,
I'm using an LDO with an enable. I'd like the LDO to be active when either of two other voltages (+5VDC or +3.3VDC, both from other LDOs) are present. My proposed solution is a 100k pull-up to +3.3V in series with a diode and then a 100K pull-up and diode to +5V, both connected to the EN pin of the LDO. So, if either +3.3V or +5V are present the EN pin would be pulled high. Seems simple enough, just curious if anyone spots any flaws or if there would be a problem when both +3.3V and +5V are on at once.
Thanks for any thoughts.
