Wire area difference when using DC and RC for the same design
tavidu
Member level 1
when I use DC and RC(RTL compiler) for a same design, the gate count result is no much different, but wire area differ too much.
Now I'm evaulate these two tools, and wire area is the one that I need to concern?
Less wire area, more routable in layout period?
Atre
Full Member level 1
Eindhoven, the Netherlands
Re: wire area
Hello,
Deppending on your .lib file, you have there a wire load model(s). Wire area is an estimated value during synthesis.
IF you want to be more accurate in your evaluation, you need a wire load model, for the design you are using, coming from the P&R tool.
Hope this helps!
jingli888ca
Newbie level 5
wire area
A wire load model helps, but eventually it is decided by the P&R tool and your floorplan.
Also, you should worry about the certain instantiated modules, if there are a lot of congestion then it is better to resolve it from RTL phase.
Hards
Member level 1
Re: wire area
read this u will clear
newcpu
Member level 4
wire area
It is a paper from SNUG.
