will a case statement work inside a for loop ( vhdl)
ramz
Junior Member level 2
case statements in vhdl
for i in 0 to 3 loop
case(i)
when 1 => some statement executed
when 2 =>
when 3 =>
when others =>
end case
end loop
i tried to use like this, but does not work.. any suggestions appreciatedd
for loop within case statement in vhdl
try this
process(clk,rst,ena)
	begin
		if (rst = '1') then
			for i in 0 to 2 loop
				case (i) is
					when 0 =>
					when 1 =>
					when 2 =>
				end case;
			end loop;
		elsif (rising_edge(clk) and ena = '1') then
				case (i) is
					when 0 =>
					when 1 =>
					when 2 =>
				end case;
			end loop;
		end if;
	end process;
    ramz
loop case statement vhdl
What do you mean with "but does not work". It's legal VHDL syntax and thus basically works (if you supplement the missing ";" delimiters).
On the other hand, as written above , the code is completely meaningless (also the expanded code suggested by sval).
You can simply write a sequence of statements without the for loop iteration scheme and the case construct, it has the same effect.
But it may have a purpose in a more complex iteration scheme.
    ramz
