tlz
I'm using an antenna that works in the range from 1 GHz to 3 GHz. I want to match impedances between a cable from the transmitter and the input amplifier and from the output amplifier and the cable to the receiver to get the maximum power and the lossless.
I found that there are some techniques called Bode-Fano equations, five λ/4 impedance transformer and stub tuner when you use a wide range of frequencies (1GHz to 3GHz) instead only one frequency, but I don't understand it how could I used it. Can you help me?
