[SOLVED] Why we need Wgl file format
shalin mandiwala
Junior Member level 3
Hello All,
My Question is Why We need WGL(Waveform Generation Language) File format when we have STIL file?
We already have STIL file for pattern information then why we need WGL file?
Thanks in advance.
dpaul
Advanced Member level 5
Germany
I have only worked with STIL patterns, had never generated WGL. Even then we had to convert STIL to a proprietary pattern so that they could be fed into Advantest.
Whavever little I know and making an educated guess, the reason might be for operatability with various tools/scripts/software.
dpaul
Germany
If you are talking about ATE testers, machines which are used for post production tests, then these ATEs have their own formats. WGL or STIL test vectors generated by ATPG tools have to be converted into another format suitable for the target ATE tester.
e.g- Advantage T series testers do not support the STIL or WGL data format.
