why we don'r recommend use tri-state in the ic ??
A.Anand Srinivasan
Advanced Member level 5
India
because it is left open and hence there is a very good chance of noise coupling and hence leading to erroneous output...
carv_13
Member level 2
Tri state devices have enable signals which can cause either a bus contention or a bus float fault. As a result when ATPG analysis is done on them, the logical values on these can result in the enable line faults being undetected.
xlxlyu
Junior Member level 2
it also has some power problem,
Tri state may casue pmos&nmos open at the same time,
so there is a direct paths from the supply to ground.
