why this timing report(ISE) says there are Levels of Logic
rogeret
Member level 4
questions of timing report(ISE) about logic levels/tas
Hi ,
Could you help me?
The following timing path report is extracted from the final timing report after PAR. My expected period of clock is 4 ns. My target device is xc7v585t-3-ffg1157 (Virtex 7 family).
1.
I cannot understand why the following timing report tells me there are TWO levels of logic in this timing path.
The delay type in this path is sequentially presented : Tshcko -> net -> Tdspdo_B_P_MULT -> net -> Tas.
In my opinion, there is only ONE level of logic because I can see only one logic---DSP48.
Does the delay tpye----tas imply one level of logic? I dont think so because tas is similiar to setup time which is definitely not logic delay.
Here(https://www.xilinx.com/support/documentation/user_guides/ug364.pdf) is the meaning of tas:
At time [B][U]TAS [/U][/B]before clock event 1, the address (2) becomes valid at the A/B/C/D inputs of the RAM
2.
Why does tas here have a negative value?
3.
Considering that there is no explicit RAM in my RTL design, why ,after I disable the option of "RAM EXTRACTION" to extinct logic implemented by RAM,does the delay----tas still exist? In my opinion , tas delay type is related to RAM and delay of tas type imply the existence of RAM, so I cannot understand the reason for the existence of tas delay type (= RAM) considering no explicit RAM in RTL and the disabled "RAM EXTRACTION" option.
Timing report:
  1. --------------------------------------------------------------------------------
  2. Paths for end point bx6/r_yw1_6 (SLICE_X63Y327.C5), 1 path
  3. --------------------------------------------------------------------------------
  4. Slack (setup path): -0.463ns (requirement - (data path - clock path skew + uncertainty))
  5. Source: t_nextb/b11_0_1 (FF)
  6. Destination: bx6/r_yw1_6 (FF)
  7. Requirement: 4.000ns
  8. Data Path Delay: 4.388ns (Levels of Logic = 2)
  9. Clock Path Skew: -0.040ns (0.975 - 1.015)
  10. Source Clock: clk_BUFGP rising at 0.000ns
  11. Destination Clock: clk_BUFGP rising at 4.000ns
  12. Clock Uncertainty: 0.035ns
  13. Clock Uncertainty: 0.035ns ((TSJ^2 + TIJ^2)^1/2 + DJ) / 2 + PE
  14. Total System Jitter (TSJ): 0.070ns
  15. Total Input Jitter (TIJ): 0.000ns
  16. Discrete Jitter (DJ): 0.000ns
  17. Phase Error (PE): 0.000ns
  18. Maximum Data Path at Slow Process Corner: t_nextb/b11_0_1 to bx6/r_yw1_6
  19. Location Delay type Delay(ns) Physical Resource Logical Resource(s)
  20. ------------------------------------------------- -------------------
  21. SLICE_X62Y251.DMUX Tshcko 0.315 reset_IBUF_589 t_nextb/b11_0_1
  22. DSP48_X2Y131.B0 net (fanout=4) 1.391 t_nextb/b11_0_1
  23. DSP48_X2Y131.P6 Tdspdo_B_P_MULT 2.280 bx6/Mmult_yw1x bx6/Mmult_yw1x
  24. SLICE_X63Y327.C5 net (fanout=1) 0.406 bx6/yw1x<6>
  25. SLICE_X63Y327.CLK Tas -0.004 bx6/r_yw1<8>
  26. bx6/yw1x<6>_rt
  27. bx6/r_yw1_6
  28. ------------------------------------------------- ---------------------------
  29. Total 4.388ns (2.591ns logic, 1.797ns route)
  30. (59.0% logic, 41.0% route)
Re: questions of timing report(ISE) about logic levels/tas
1.
There is only one level the SLICE_X63Y327 probably contains an output register. You should generate a post mapped schematic to look at the implementation details.
2.
This would just mean the register has a negative setup time, i.e. the clock can arrive before the data.
3.
Tas is a setup time for the A/B/C/D inputs of a slice. It is used for both inputs to a flip flop or for the address input to a LUT RAM.
Hi ads_ee ,
Thanks!
But it is still hard to imagine the existence of a register with a negative setup time. A negative setup time may not accord with the theory of digital circuit.
and if you want a picture:
https://cdstahl.org/?attachment_id=41
as for the extra level of logic, I'm guessing there is something in your code that ends up inferring an extra level, or that the tools have chosen to use a logic element for routing for some reason. in this case, I'm assuming the DMUX muxes in on path for reset and one for non-reset.
Maybe, this is a possible explanation.
But , I dont think it is like this in this case.
In the following timing path, there is still a SLICE_X62Y251.DMUX at the beginning of the path which has only ONE logic level.
Where the difference btw the 2 paths locates at is the SLICE_X63Y327.CLK with delay type of Tdick at the end of this path.
SO , I suspect that why the above timing path has TWO logic levels is that it has SLICE_X63Y327.CLK with delay type of Tas at the end of its path.
Paths for end point bx6/r_yw1_7 (SLICE_X63Y327.DX), 1 path
Slack (setup path): -0.444ns (requirement - (data path - clock path skew + uncertainty))
Destination: bx6/r_yw1_7 (FF)
Data Path Delay: 4.369ns (Levels of Logic = 1)
Maximum Data Path at Slow Process Corner: t_nextb/b11_0_1 to bx6/r_yw1_7
Logical Resource(s)
t_nextb/b11_0_1
DSP48_X2Y131.P7 Tdspdo_B_P_MULT 2.280 bx6/Mmult_yw1x
bx6/Mmult_yw1x
SLICE_X63Y327.DX net (fanout=1) 0.371 bx6/yw1x<7>
SLICE_X63Y327.CLK Tdick 0.012 bx6/r_yw1<8>
bx6/r_yw1_7
Total 4.369ns (2.607ns logic, 1.762ns route)
(59.7% logic, 40.3% route)
