fahim1
Member level 4
according to the following code and test bench at each rising edge of the clock the signal registers value should participate in the calculation but it doesnt happen:
for example ;
at the red circle when x is 5 and signal reg is (5,0,0) the out put should be y=20 (y=x +shl (reg(2)))
but here it calculate the y with the previous values of reg which is (0,0,0) and i dont know why??
i would appreciate if some body help me?
---------main program------------
for example ;
-----------------------------test bench---------------------library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.all;
use IEEE.std_logic_unsigned.all;
entity fir3 is
port( x : in std_logic_vector (3 downto 0);
clk,rst : in std_logic;
y : out std_logic_vector (7 downto 0));
end fir3;
architecture fir3_arch of fir3 is
type registers is array (2 downto 0) of std_logic_vector(6 downto 0);
type coefficients is array (3 downto 0) of std_logic_vector(3 downto 0);
signal reg : registers := ("0000000","0000000","0000000");
constant coef : coefficients := ("0001","0010","0011","0100");
begin
process(clk,rst)
variable acc,prod : std_logic_vector (7 downto 0) := (others => '0');
variable temp : std_logic_vector (6 downto 0) := (others => '0');
begin
-----------------reset--------------------
if rst='1' then
for i in 2 downto 0 loop
for j in 6 downto 0 loop
reg(i)(j) <= '0';
end loop;
end loop;
-------------register inference + MAC -----------
elsif (clk'event and clk='1') then
acc := (others => '0');
acc := "0000" & x ; --because c0=1 we dont have to multiply
temp := "000" & x ;
prod := ((reg(2)(5 downto 0))& '0') +((reg(1)+reg(1)(5 downto 0))&'0') +((reg(0)(4 downto 0))&"00");
acc := acc + prod ;
reg <= temp & reg(2 downto 1 );
end if;
y <= acc;
end process;
end fir3_arch;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
USE ieee.numeric_std.ALL;
ENTITY fir3_testbench IS
END fir3_testbench;
ARCHITECTURE fir3_testbench_arch OF fir3_testbench IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT fir3
PORT(
x : IN std_logic_vector(3 downto 0);
clk : IN std_logic;
rst : IN std_logic;
y : OUT std_logic_vector(7 downto 0)
END COMPONENT;
--Inputs
signal x : std_logic_vector(3 downto 0) := (others => '0');
signal clk : std_logic := '0';
signal rst : std_logic := '0';
--Outputs
signal y : std_logic_vector(7 downto 0);
-- Clock period definitions
constant clk_period : time := 11 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: fir3 PORT MAP (
x => x,
clk => clk,
rst => rst,
y => y
-- Clock process definitions
clk_processrocess
begin
clk <= '0';
wait for clk_period/2;
clk <= '1';
end process;
x <= "0000",
"0101" after 11 ns,
"1010" after 22 ns,
"1111" after 33 ns,
"0000" after 44 ns;
END fir3_testbench_arch;
