Jun 21, 2006 #1 A Alan_Nesta Member level 5 Joined Aug 11, 2005 Messages 80 Helped 5 Reputation 10 Reaction score 0 Trophy points 1,286 Activity points 1,708 When design ldo regulator a rhp pole occured, Why did it happen? and how to cancel it? Thanks!
Jul 19, 2006 #2 K kevinwang123 Junior Member level 1 Joined May 17, 2005 Messages 15 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,406 Re: problem about ldo Do you use PMOS pass device? You can use simulator to find where the RHP pole is and find the reason,or analyse each stage to find the RHP pole by theory,then you can get the solution.
Jul 19, 2006 #3 ipierre Junior Member level 2 Joined Jul 7, 2006 Messages 21 Helped 3 Reputation 6 Reaction score 0 Trophy points 1,281 Activity points 1,382 Re: problem about ldo Here is a good reference of LDO regulator. "Current Efficient, Low Voltage, Low Drop-out Regulators" by Gabriel Alfonso Rincon-Mora (Freely download) Regards
