why most comprator using ramp signal to compare
baby_1
Advanced Member level 1
Hello
as you see this image
why the most comparator use the ramp signal to compare?why they don't use a fix and specified voltage to compare?
The analog comparator designed with opamp will usually have a finite offset in its terminals.
So the minute difference voltage in its input terminals is best depicted in the comparator output only if the input signal is linearly increasing.
Ramp is one such signal and we can have the comparator's output switched to V++ exactly where the ramp input crosses the reference voltage (considering without offset)
Reactions: baby_1
    baby_1
is the ramp try to make PWM Puls?
Yes. Ramp input is one of the analog signal which is needed for PWM pulse generation for various electrical and electronic applications.
Refer the below pdf for details.
You can ask any doubts regarding analog comparators and mixed signal vlsi circuits as i worked on those areas.
All the best.
All the best.
  • Pulse Width Modulator.pdf
Dear baby_1
Hi
The ramp or triangular wave are , the best things to create PWM and SPWM . and the reason , is , in the spectrum !
Best Wishes
Goldsmith
Reactions: baby_1
    baby_1
