Which transistor would best suit for 8.3 - 8.7 GHz X-Band LNA design?
vedagarbhamsandeep
Full Member level 2
Bangalore
Could someone tell me which Transistor would best suit for 8.3 - 8.7 GHz ? and also a design approach to meet the requirements.
Gain: 45dB
Gain Stability: 0.5dB
Output Impedance 50 ohms
I/O VSWR: < 1.3
DC Power: 12V
Any related documents to obtain the same would be of great help. I would be using Ansoft Designer and CST. Please comment on the same.
How many stages of LNA would be required to obtain the target Gain ? and also what Bandpass Filter (my choice is hairpin filter as of now) will be best suited ?
vfone
Advanced Member level 5
low noise amplifier design
To get 45dB of gain at this frequency from one transistor is impossible. You need at least 3 stages.
Try GaAs FETs from AVAGO:
Hairpin Filter at this frequency and bandwidth should be fine.
imado_60
Junior Member level 1
lna design using ansoft designer
Try BFR949f
neazoi
Greece
x-band
Gain: 45dB
I/O VSWR: < 1.3
DC Power: 12V
To get so much gain at this frequency you need a multi stage amplifier. You mention that this is an LNA but there is no indication about the NF of the amplifier you need to construct. What is its use? A very low noise can be accomplished by the MGF4919G and the NE3210S01 as can be seen in the gk-electronics.gr website, but they are expensive.
I would say these are among the best transistors as far as concern NF in these frequencies.
Note: NF is defined almost totally by the first stage of your amplifier, i.e. the first transistor, so you probably only need 1 of these.
The rest can be higher noise ones without affecting the performance of the LNA too much. See here for a calculator: **broken link removed**
PalashJain
Newbie level 2
lna design in edaboard
hello everyone
i am a ug student and doing a project on low noise amp
i want the basic tutorial + design circuit for the same.
thanx
neazoi
Greece
low noise amplifier x-band
An LNA is no different than a preamplifier. So any small signal amplifier/preamplifier tutorial will be fine for you. The only thing with LNAs is that the first stage needs to use a low noise active device (transistor), so you have to look for a low noise transistor/MMIC for the frequency you want.
And you need to define what low noise means to you. If 3db total NF can be defined as a low noise amplifier by your project supervisor, then you can just use an MMIC at lower microwaves. See www.gk-electronics.gr for short data and samples on some MMICs.
Noise figures of <1db are more difficult and expensive to achieve.
