Which std logic code is better ?
vlsi_freak
Full Member level 2
Full Member level 2
Which one would you use and why?
I vote for the first method???
signal a_sig : std_logic_vector(n downto 0);
signal b_sig : std_logic_vector(n downto 0);
process(a_sig,bsig)
variable c_sig : std_logic_vector(n downto 0);
begin
c_sig := a_sig-bsig;
a_is_smaller <= c_sig(c_sig'high);
end process;
process(a_sig,bsig)
begin
if(asig < bsig) then
a_is_smaller <= '1';
else
a_is_smaller <= '0';
end if;
end process;
Re: Which one is good
I think the answer to your question depens upon the synthesis tool that you use...the less than comparator might have less number of gates than the subractor... so i guess the second code will be better...
First approch is just taking one substractor and second approch is taking comparator.
First approch is taking less combinational delay than second one. So I will also go for First approch.
hi,
depends on synthesis tool.
thanx......
    vlsi_freak
