Internal logic of IO pads
fragnen
Full Member level 4
Full Member level 4
Do IO Pads have any digital logiv inside them? What is the purpose of that digital logic inside them?
The output high and low side switches want their
gates driven to make H, L and Z. You need a trivial
couple of gates for that decode and of course the
drive taper chain (inverters).
Do you want to mean the three state buffer which has three states H, L and Z by
in your above statement?
What do you mean by drive taper chain? What is the purpose of this drive taper chain?
Pads are driven by buffers and all cascaded CMOS buffers have a certain taper of lower impedance higher load capacitance for each stage or in other words a higher current conductance which can be derived from Beta = β = 2*Ids / (Vgs - Vt for all enhancement FETs.
This increase in conductance * risetime is called a tapered buffer. Now a reverse body bias (RBB) design on input stages allows much lower RdsOn without the major penalty of rising Cin & Cout or Ciss, Coss with minimal penalty in speed.
Bonus question.
How many stages do you think it takes to go from 50 Gohms ||5 pF to 50 Ohm logic for 100 MHz pulses or 500 microohms power half-bridge for 1MHz pulses? i.e. How do you determine the optimal gain in gm for the taper with minimal losses? ( while avoiding shoot-thru with a wide tolerance on Vt.
--- Updated ---
FWIW https://www.researchgate.net/public...ody_Biasing_Technique_for_CMOS_Tapered_Buffer
LaTeX Commands Quick-Menu:
