Which resistor layout is better one?
amara
Member level 1
WHICH RESISTOR IS GOOD
while doing layout for Resistor which resistor layout is better one.
Re: WHICH RESISTOR IS GOOD
It depends on your application and the value of the resistor you want.
Every material has a different sheet resistance, the figure below can give you an idea of the sheet resistance material!! And you have to pay atention in the parasitics, temperature variation and area that every kind of resistor has, usually diffused resistors (n++ or p++) has parasistic diodes with the substrate but they get high resisitor values and they have a high temperature coefficient.
Poly resistors has a medion value and thet have parasitic capacitors with the substrate. And they can be floatind resistors.
In your inductor post you can download the PAS_ELEM.rar where you can design easily resistors, capacitors and inductors.
Regards
HI!
For more ideas about different IC resistors and their comparative study, Plz go through
1) CMOS circuit design,modeling & simulation By: Jacob Baker
2) CMOS Mixed signal Design By: JacoB Baker
u will surely get what u r looking for..
