Feb 17, 2012 #1 A.Rashad Member level 4 Joined Jul 27, 2011 Messages 69 Helped 6 Reputation 10 Reaction score 5 Trophy points 1,288 Location Pune Activity points 1,792 Hi , which registers to configure for setting PWM for timer 0 or 1 in AVR ATMEGA 32? Where can i find some example code?
Feb 17, 2012 #2 Tahmid Advanced Member level 6 Joined Jun 17, 2008 Messages 4,756 Helped 1,798 Reputation 3,588 Reaction score 1,656 Trophy points 1,413 Location Berkeley, California Activity points 30,584 Re: Avr pwm on Timer 0/1 You should read these: www.atmel.com/Images/doc2542.pdf View topic - [TUT] [C] Newbie's Guide to AVR PWM (Incomplete) :: AVR Freaks You should also go through the datasheet where you can find the registers: www.atmel.com/Images/doc2503.pdf Hope this helps. Tahmid.
Feb 17, 2012 #3 W Wafeeq Member level 3 Joined Jul 26, 2010 Messages 61 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,288 Location Pakistan Activity points 1,728 Re: Avr pwm on Timer 0/1 i am also having same problem. i want to take two PWM channels with both different frequencies. i want to change the frequency on runtime.
