Which is better for DSP implementation, FPGA or TMS320?
pngzhi
Member level 3
FPGA is better for dsp implenetation or TMS320?
tms320 vs fpga
Hi Friend,
TMS 320 series is very efficient due to its very good architecture.
But make decisions according to your application.
Regads,
Avinash.S.
    pngzhi
division tms320
It depends on your ability to write C/C++ or Verilog/VHDL code and also on your application. For example if your application involves lots of division operations, it may be better to design your circuit in HDL, since some of the TMS320 series doesn't have hardware division ability.(Assumed that you can write the necassery HDL code good enough to make divisions faster than the TMS of course).
If you're going to implement digital filters or other signal processing operations, TMS series (or some other DSP) would be probably faster because they have very good architecture with lots of features optimized for DSP algorithms.
Regards.
    pngzhi
Re: FPGA or TMS320
I would say go for TMS320 for DSP applications.
Since the architecture of TMS320 suits the complex algorithms of DSP
    pngzhi
Re: FPGA or TMS320
For DSP applications, latest DSP processors better than FPGAs.
If you need more details, contact me.
    pngzhi
Re: FPGA or TMS320
Once again the recurrent question comes back: Better FPGA or DSP for signal processing?
The answer is always the same: depends on the application.
DSP are easier to program (most of the work is in C/C++) and generally have good processing power (latest chip from TI runs at GHz speed!) but if you have to process high data rates streams even the most powerful DSP could be too slow and so you have to do all the job in FPGA/ASIC or at least to use an FPGA to do the higher rate processing acting as co-processor to a DSP or GPP.
Beside this simple considerations the designer should evaluate also other parameters like costs and time to market.
If you have time to spent you could search in this same forum and/or in the web and find lot of material about this subject.
Regards
Mowgli
    pngzhi
FPGA or TMS320
As mowgli says, it depends on the application. My applications usually have large amounts of moderately simple calculation, and FPGA wins by a landslide. The signal processing that I'm now doing in one medium-size FPGA would require dozens of TI's most powerful DSP chips. From my point of view, DSPs went obsolete about eight years ago. However, your application may be better served by a DSP chip.
    pngzhi
hello
i wanna make a portable device battery powered for real time fft and digital filters.
i need to low power chip.
my device use from 4.3 inch tft touch screen for display.
tms320vc5509 is a good choice
cycloneIII better than from tms320vc5509?
please advice me.
thank you
