Jun 17, 2005 #1 E ethan Member level 3 Joined Jul 7, 2004 Messages 67 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 942 Hi there, Which EDA tool have you usually used for switch-capacitor amplifier simulation? Cadence? or ADS? or others? Which is better? Ethan
Jun 18, 2005 #2 M mitgrace Full Member level 6 Joined May 8, 2004 Messages 367 Helped 6 Reputation 12 Reaction score 2 Trophy points 1,298 Activity points 2,526 i think hspice or spectre is better . but if you run the whole chip simualtion , the adit is better than other tools .For my experiment
Jun 18, 2005 #3 A ala Member level 2 Joined Jun 30, 2003 Messages 44 Helped 4 Reputation 8 Reaction score 0 Trophy points 1,286 Activity points 372 hspice is a class analysis tool, After the snps merge the ISE, it shall get a better future
Jun 25, 2005 #4 H hanm Member level 4 Joined Nov 30, 2002 Messages 78 Helped 4 Reputation 8 Reaction score 0 Trophy points 1,286 Activity points 519 spectre of cource,you can easily do trans and ac analysis. hanm
Jun 25, 2005 #5 Y yibinhsieh Full Member level 4 Joined Apr 25, 2005 Messages 194 Helped 19 Reputation 38 Reaction score 5 Trophy points 1,298 Activity points 2,845 I think the spectre can simulate the transcient nosie of switch-capacitor circuits. You can use PSS, and PNOISE to get the noise information. Yibin.
Jun 27, 2005 #6 E eda4you Full Member level 5 Joined Sep 17, 2002 Messages 256 Helped 24 Reputation 48 Reaction score 11 Trophy points 1,298 Activity points 2,325 In SpectreRF you can also use the PSS analysis! look at the following link: https://www.designers-guide.org/Analysis/sc-filters.pdf
