Which 16 bit microcontroller is the best ?
ZeleC
Full Member level 5
sta2051 development kit
which 16 bit uC is the best ?
performance wise , money wise?
Re: 16bit uC
For what applications ?
CPU Speed (MIPS), memory ( Flash & RAM ) requests ?
I/O pins count ?
Peripheral controlers Timer, PWM, Serial, ADC, DAC ....
For low power and medium speed look TI MSP430 ultra low power
flash microcontrollers.
http://www.ti.com/msp430
Re: 16bit uC
So far, the 16 bit MCU that i'm using is m16c Renesas MCU. Can do all the requirement that i want...
Try to look for this website:
www.renesas.com
16bit uC
im looking for a 16bit uC that can support hard mathematics with extended mode addressing and it is not necessary a low power . with 10 bit ADC and UART
Re: 16bit uC
What mean "hard mathematics" ? Integer or floating point ? needed speed MIPS FLOPS ?
What is requests for "extended mode addressing" ? RAM ROM size ?
16bit uC
why do u not select the 32 risc? it is more usable than the 16bit
Re: 16bit uC
ive been an 8bit uC programmer hc11 and PIC16F for mainly 3 years , and i want to start with 16bit ,i think that 32 bit is more expensive then 16bit :roll:
i was impressed with the c16x series from infineon ,but the problem was if i wanted to buy a development kit to start learning the development kits available are all expensive .
so im searching for a general 16bit that has affordable development starter kits and that can support complex design .
Re: 16bit uC
agree with dainis:
MPS430 is low consuption 16bit uC
LPC2119 @30MHz is very cheap (around 10 euros) (128K Flash, 16K RAM UART, CAN and 4Ch 10 bit ADC)
//a
16bit uC
ok thank you guys
now between the lpc2xxx and mps430 which of these two microcroller offer more litterature and is more easy to learn .
Re: 16bit uC
If you have a good compiler/debugger it's the same thing!
//a
Re: 16bit uC
hi
Why cant dsPic frm microchip
I hope its also good.
Regards
Gopi
Re: 16bit uC
ZeleC said:
ok thank you guys
They are both very popular devices, but for different reasons.
MSP430 is very popular for battery operated devices because of it's extremly low power consumption.
LPC2xxx is a 32-bit ARM7TDMI MCU which is much faster than MSP430.
The perfomance of the 16-bit MSP430 is comparable to the 8-bit AVR.
ARM is some sort of "industry standard" among 32-bit MCUs.
You can compare it to 8051 in the 8-bit world, because there is so many different verdors of ARM MCUs, just like the case with 8-bit MCUs.
ARM7TDMI can run in either 16- or 32-bit mode, with two different instructin sets. In 16-bit mode it uses the THUMB instuction set and in 32-bit mode it uses the ARM insruction set. Using the 16-bit THUMB instruction set will make the code smaller in most applications but will also make it slower.
Try to read "Introduction to Atmel AT91 ARM7TDMI-based Microcontrollers": **broken link removed**
This is a good introduction to ARM7TDMI MCUs and there's a good comparison between the ARM7 instruction set and the THUMB instruction set.
ARM vs. THUMB: **broken link removed**
You should also read this new press release from Atmel:
Atmel Introduces World's First Sub $3 ARM7 Flash Microcontroller
The brand new AT91SAM7Sxx seems very promising, and they will be a very stong competitor to Philips LPC2xxx in the low end ARM market.
They will even challange some of the high-end 8-bit MCUs like Atmels own high pin-count ATmega AVR's.
Both Philips LPC2xxx amd Atmel AT91SAM7Sxx has 5 V tolerant inputs, but not all ARM7 families has that.
There is also another popular 32-bit MCU core called MIPS.
Check out www.arm.com and www.mips.com
swapgo said:
hi
It seems too expensive compared to ARM7 in my opinion.
Re: 16bit uC
ZeleC said:
so im searching for a general 16bit that has affordable development starter kits and that can support complex design.
Check out this cheap AT91SAM7S64 starter kit:
Evaluation board + IAR C-compiler + JTAG ICE for only €295
AT91SAM7S64-IAR, Evaluation kit:
http://www.mscbp.hu/download/ARM/SAM7S64_IAR_customer.pdf
If you want a cheap dev. board for the MSP430 or LPC2000 families, then try to check out this site:
http://www.olimex.com/dev/index.html
16bit uC
one think i noticed for msp430 that it doesnt support extended memory and the max memory is 60k flash and the lpcx series have this option ? ??
And what do you think guys of the infineon c167 16 bit microcontrollers im assuming that its a good performance uC especially that they are the heart of Siemens s7-300 PLCs?
Re: 16bit uC
ARM7 has better performance than C16x.
Remember that ST makes an C16x compatible MCU called ST10.
ST also makes an ARM7 MCU called STR7.
http://www.stmcu.com/index.html
Since Infenion is a Siemens company, it's only natural that they use their own MCU.
I think C16x/ST10 is very popular in industrial enviroments and for motor controls.
But remember, you should not only compare price/performance, but also what pheriphals is on board and maybe extended temperature ranges and EMC protection for harsh enviroments etc.
Some MCU has high-res. PWMs and otheres has no PWM or only low res. Some has high-res. ADC some as no ADC. Some diappates more power than others. So it all depends of what you are going to use it for.
There's a difference if you want to run embedded Linux or if you want to control a motor or something else. Some MCUs are good for one purpose, while other MCUs are better for other purposes. There is no such thing as the best MCU.
Re: 16bit uC
Nice talk but!
Can anyone put PRICES???
I want to use a STR7 variant named STA2051 but i must pay $40K for gps lib,
and USB is only for slave, not on-the-go, so sux, and i must buy a bundle of 100k pieces/year...
What company can do nice on developers?
For a task in view, an AT91SAM7S256 can almost do the job ...
Can anyone talk about prices/qtties ???
Sometimes price is more important then what ever else..
Thanx
:D
