What's wrong with my current distribution in HFSS?
Ruritania
Member level 5
how to get current distribution in hfss
Hi, all,
I'm using HFSS to simulate an on-chip inductor, but whatever setting I used, still get bad results comparing with the measured data: the inductance is about 0.1nH larger, and the quality factor is about 6 less.
Someone told me that the current distribution of the inductor was not smooth. But I just don't know how to make it smooth? What might cause such situation to happen in HFSS?
Attached please find the uploaded Jsurf and Jvol, thank you.
Ruri
cvenkat
Full Member level 1
current distribution hfss
im also looking for some reply!!
Added after 44 seconds:
or u use ur simulation setting and simulate the structure in manual.....compare the result
snowland
Junior Member level 2
how do you excite the structure?
using a lumped port between the feed line?
antennas321
Member level 3
Depending on the frequency, current will crowd to the edge of the trace (skin effect) and will also crowd to areas that are near other conductors (proximity effect). You can see this in multiple conductor transmission lines such as twin lead or busbar.
I would recommend using IE3D for planar inductor analysis. It is a moment-method tool that is better-suited for solving for currents than HFSS (which solves for E-fields).
wlcsp
Full Member level 3
Are you sure you have used the correct material properties?, since the substrate and metal properties may vary. Did solve "inside" of the metal?
wlcsp
plasma
Advanced Member level 2
Hi Ruritania
That's the reason that your loop didn’t work.
you Forgot little slot
pl
plasma
this explain the all picture.
cvenkat
Full Member level 1
hi,
i donno much abt induator design. So what r u saying the last one (with slot) is the correct inductir structure to simulate?
please explain
thanx
