VitalyM4
Junior Member level 3
Hi !
I created divider (255/divisor), it works well for all the cases except one when divisor equal to 1, then result is 0 instead of 255.
I know that exists some page where you can set divident and divisor and see all the stages of non-restoring division. Does someone know adress?
Thanks in advance!
module div (
SCAN_EN_SCLK , /*Scan Enable*/
SCAN_IN_SCLK , /*Scan Input*/
SCAN_OUT_SCLK, /*Scan output */
rb_por_cr , /*Asynchronous reset*/
SCLK , /*Divider Clock*/
divisor , /*divisor*/
we , /*write enable - initiate dividing*/
result /*division result*/
/*Port direction and types*/
output [6:0] result ;
reg [6:0] result ;
input [7:0] divisor ;
wire [7:0] divisor;
input SCLK ;
wire SCLK ;
input we ;
wire we;
input rb_por_cr;
input SCAN_EN_SCLK;
input SCAN_IN_SCLK;
output SCAN_OUT_SCLK;
/*Internal signal declaration*/
reg [8:0] cur_divident;
reg [6:0] cur_divisor;
reg [2:0] bit_count;
integer i;
reg [2:0] max;
/*Functional description*/
/*Create logic finding MSB 1*/
always@(divisor)
begin
max=0;
for(i=7;i>0;i=i-1)
if(divisor[i]==1'b1 & i>=max)
max=i;
end
wire [7:0] tmp_div=divisor<<(8-max);
/*Division*/
always@(negedge rb_por_cr or posedge SCLK)
if(!rb_por_cr)
begin
cur_divident<=8'd0;
cur_divisor<=8'd0;
bit_count<=3'd0;
result<=7'd0;
end
else if(we)
begin
cur_divident<=9'd255-tmp_div;
cur_divisor<=tmp_div>>1;
bit_count<=8-max;
result<=7'd0;
end
else if (bit_count>3'b000)
begin
if (cur_divident[8]==1'b0)
begin
cur_divident <= cur_divident-cur_divisor;
result[bit_count-1'b1]<=1'b1;
end
else
begin
result[bit_count-1'b1]<=1'b0;
cur_divident <= cur_divident+cur_divisor;
end
bit_count<=bit_count-1;
cur_divisor<= cur_divisor>>1;
end
endmodule
Thanks in advance!
