What's the difference between always @ (posedge clk) and @ (posedge clk)?
spartanthewarrior
Full Member level 2
Can anybody tell me that What is the difference between
and
@ (posedge clk)
Re: Always Block
the difference is that when you write @(posedge clk) it's just a conditional statement, which checks for clocks positive edge. And always @(posedge clk) is continous by its nature and is usually used for modelling of synchronous logic like flip-flops.
Re: Always Block
Hai dude,
always@ (pos edge)
This is like saying at all pos egde do the job always.
no condition to contiune with pos edge only.
@pos edge
this is saying like do the job inly at pos edge.
conditioning
Re: Always Block
always @(posedge clk) means at every positive edge of the clock the code inside the always block will be executed.
Always Block
the difference is the "always"
"@ (posedge clk) " is checked somtimes, if "always" is put ahead, it's "always" checked during simulation
Re: Always Block
when you use always it means that all posedges of the clock this should happen. @() is just a conditional statement when you synthesize it may be then u will find the difference
Re: Always Block
The first one ,i.e.
always@(posedge clk)
The block under this executes at every postive edge of the clock
@posedge clk
This means that the block under this executes only once and that too, only at the first posedge of the clock
