What's the best SRAM configuration? (4T, 5T, 6T, etc)
ajhunt18
Member level 1
What's the best SRAM configuration? (4T, 5T, 6T, etc). I am designing an SRAM with low power and low leakage in digital implementation using Verilog coding (VCS simulation). Also, what's the best technique I can use to minimize the leakage?
Thank You!
what structure of 5T like?
4T just derived from 6T(2T as resistor in 4T).
I am actually designing in digital implementation. I will use latches instead of nmos or pmos transistors. I'll be using cross-coupled inverter.
