what's SPEF and what information does it contains?
bendrift
Member level 4
spef d_net
many time i saw back end engineer use SPEF for timing analyse and so on.
but what's SPEF and what information does it contains?
would u send some materals about it?
thank u :)
bendrift
Member level 4
standard parasitic exchange format
would someone help me?
ceyjey
Junior Member level 1
spf spef
SPEF stands for Standard Parasitic Exchange Format. It contains the parasitics extracted from the layout. Backend engineers needs these information to do post layout STA. You may search the web for the detailed information about this format.
ceyjey
icon
Member level 2
india
spef format d_net
SPEF Standard-parasitic extended format. Part of Open Verilog International's delay-calculation-system (DCS) standard. Based primarily on SPF, SPEF has extended capability and a smaller format. Although many EDA back-end tools support DSPF and RSPF, few EDA tools support SPEF at this time.
bendrift
Member level 4
spef documentation
i saw that SPEF mean standard physical exchange format.
can anybody describe the content of SPEF?
or give me a simple exmple for understanding.
thank u :)
utmseng
Junior Member level 2
AZ
what does spf mean in eda
Here is the SPEF file example I copied from somewhere.
SPEF
*SPEF “IEEE 1481-1998”
*DESIGN “top”
*DATE “Wed May 17 19:50:14 2000”
*VENDOR “Synopsys”
*PROGRAM “Star-RCXT”
*VERSION “2003.2.0.0”
*DESIGN_FLOW “PIN_CAP NONE” “NAME_SCOPE LOCAL”
*DIVIDER /
*DELIMITER :
*BUS_DELIMITER []
*T_UNIT 1 NS
*C_UNIT 1 FF
*R_UNIT 1 OHM
*L_UNIT 1 HENRY
*NAME_MAP
*5 net1
*10 insta/net2
*14 U1
*16 insta/U1
*17 insta/U2
*PORTS
*5 I *C 3.6 0
*D_NET *5 1.02e+00
*CONN
*P *5 I *C 3.6 0
*I *14:I I *C 6.76 8.94 *L 4 *D inv
*CAP
1 *5 0.60481
2 *14:I 0.413795
*RES
1 *5 *14:I 29.8492
*END
*D_NET *10 4.58e-01
*CONN
*I *16:ZN O *C 9.12 21.84
*I *17:I I *C 6.34 20.94 *L 4 *D inv
*CAP
1 *16:ZN 0.271701
2 *17:I 0.186
*RES
1 *16:ZN *17:I 16.8989
*END
For the explanation of the SPEF file, you can refer to a documentation posted by usernam
h**p://
Have fun!
tarkyss
Full Member level 6
China
spef ieee 1481-1998
RC parameter
sam31
Junior Member level 3
Toulouse , France
star-rcxt spef d_net
SPEF : parasistic parameter R (ohm) & C (farad) for RC timing modeling
Used after layout to back-annotate timing for STA & simulation
birdy123
Full Member level 3
Hi GUys,
Please cehck the details of SPEF and their syntax at the following link...
h**p://vlsi-expert.blogspot.com/2010/08/difference-between-parasitic-data.html
and
h**p://vlsi-expert.blogspot.com/2010/08/how-to-read-spef.html
hari151087
Newbie level 6
Bangalore, India
spef is extracted after routing in pnr stage. This helps in accurate calculation of IRDROP analysis and other analysis after routing. This file contains the R and C paramaters depending on the placement of our tile/block and the routing among the placed cells..
MRAMA
Banned
bangalore
Hi GUys,
and
Please see the date of the thread.....
its 05 year.. and i think they might have got solution for it by now....
DONT REOPEN OLD THREADS AS THEY MIGHT HAVE DIED LONG BACK AND NEW THREADS MAY BE OVERRIDDEN
