What is wrong with this radio circuit
F98
Hello
please help me to rectify this circuit.This circuit was working fine on breadboard but when i transfer
it to pcb it stop working.
thanks
  • crystal.doc
So the error must be on your PCB circuit. Check it, show it!
Hello erikl
Thanks for reply.
These are the pictures of PCB.
Without checking the correct connections - I think you have terribly bad solder connections, and a possible short circuit, s. the marked area.
With an Ohm meter, check for possible short circuit, and the passage of your solder connections.
Hello erikl
Thanks again for reply.After checking pcb i find following
1)No short circuit is detected
2)Every solder joint is connected with other
joint with which it should be connected
A diode in series with a capacitor cancels the diode current.
Operating a 200 MHz OP without any bypass capacitors is really a bad idea.
Generally you'll start verification of circuit by measuring all DC levels (e.g. against common ground) with a multimeter.
+Removed the capacitor but did not make any difference
+checked +ive and -ive voltages w.r.t ground which are correct
+ d.c voltage amplify when apply non inverting pin of op amp
Horrible PCB - you should look into good RF layout techniques.
What is the red wire linking the ends of the potentiometer? Looks like you shorted it out instead of using the center pin.
What is the first IC type? You have it configured to drive into a 10 Ohm load when the potentiometer is set to zero resistance and a gain of ~1000 when at maximum resistance, both very unlikely to work.
I shorted the central pin to one of its side pin to get variable resistance.
but It is in fact giving variable resistance as measured by multimeter.
My intention was to get maximum gain of 100 in case of very low signal.
what do you advise to do?
Sorry feedback variable resistance in circuit is of 1 K.
