In the ADC datasheet , it depicts that
TWO-TONE SFDR
fIN = 169.6 MHz @ 7dBFS, 170.6 MHz @ 7dBFS
Thanks.So it deduces that the f1=169.6MHz@-7dBFS and f2=170.6MHz@-7dBFS. produce the noise pattern in figure 23 under Fs=130MHz?
But if the Fs=130MHz, then the image should be located at 2x130Mhz -170.6Mhz=89.4Mhz, however in figure 23 , the -7dB is at between 31.250 - 46.875Mhz, I can't figure it out.
