What is the term Tombstone used for
Anonymous_Ricky
Advanced Member level 2
India
term tombstone
Hi all,
What is the term Tombstone used for, I just come across the term going through the threads.
Regards,
Ricky
Is used in Assembly. Refers to mostly small discrete packages that will be standing or lifting in 90 Deg hence looking like Tombstone.
Regards,
M
A tombstone-sometimes called a Manhattan skyline, crocodile, leaning tower or space rocket-is a chip component that has partially or completely lifted off one end of the surface of the pad. Tombstones may be caused by solderability variations on terminations; volume of paste; surface area of pad; variations in thermal demand of pads; solder mask thickness; paste under parts; limited placement force; and nitrogen usage.
You also can google over the net to find out more.
