what is the problem in this code?
tahboy
Newbie level 2
I need to use external interrupt by push button on RB0
but i can't return back from interrupt.
this code can not return to main program after executing interrupt.
pleas can you help me :oops:
list      p=16F628A           ; list directive to define processor
    #include <p16F628A.inc>       ; processor specific variable definitions
   __CONFIG   _CP_OFF & DATA_CP_OFF & _LVP_OFF & _BOREN_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _HS_OSC
reg1     equ 0x20
reg2     equ 0x21
reg3     equ 0x22
w_temp           equ 0x23
start:    org     0x0000
            goto    mainProg             ; go to beginning of program
itsr:                  org       0x0004
                        goto     intsup
;**************** Interrupt rotine gos here ****************
mainProg:        movlw 0x07      ;turn off comparator(PORTA = i/o)
                        movwf CMCON
                        movlw   0x90      ;GIE – Global interrupt enable (1=enable)
                        movwf   INTCON    ;INTE - RB0 interrupt enable (1=enable)& clear flag INTF
                        bsf       STATUS,RP0  ;bank1
                        movlw 0x3f
                        movwf OPTION_REG
                        movlw 0x00
                        movwf TRISA
                        movlw 0x01
                        movwf TRISB
                        bcf       STATUS,RP0  ;bank0
main:               movlw 0xff
                        movwf PORTA
                        call      delay500
                        movlw 0x00
                        movwf PORTA
                        call      delay500
                        goto     main
;;;;;;; delay500;;;;;;;
delay500:
            movwf w_temp
            movlw   0x04  ;0x04
            movwf   reg3
L3:     movlw   0xff     ;0xff
        movwf   reg2
L2:     movlw   0xff     ;0xff
            movwf   reg1
L1:     decfsz  reg1
        goto    L1
        decfsz  reg2
        goto    L2
        decfsz  reg3
        goto    L3
        movf        w_temp,0
            return
intsup:
                        movlw 0x01
                        movwf PORTA
                        call      delay500
                        movlw 0x02
                        movwf PORTA
                        call      delay500
                        bcf       INTCON,INTF
                        bsf       INTCON,INTE
                        retfie                ;return to mainProg
              END                       ; directive 'end of program'
If you look in the Mplab folder for the Templates folder and then for the 16F628A.Temp you will see an example of whats called ISR Context Saving.
When an Interrupt is detected, the current operation and relevant system registers must be Saved so after the ISR is complete you can correctly restore and return to where you left off in the main flow.
At a guess, you are trashing the W and STATUS regsters and maybe the bank selection bits in your interrupt routine.
As it looks like you are using MPLAB, I STRONGLY suggest you copy the template file "16F628ATEMP.ASM" and edit your own code into it. That file already includes the basic interrupt handler routines, including the code to preserve the W and STATUS registers.
I would also recommmend that you do not use delay routines inside interrupt routines. Generally interrupts are used when something needs priority attention over the normal flow of instructions and while in the ISR all other interrupts are disabled and will not be recognized. It may not make much difference in your simple code but in most applications it's best to get out of an ISR as quickly as possible.
Basically your delay routine never comes out of loop.
delay500:
            movwf w_temp
         movlw   0x04  ;0x04
         movwf   reg3
	     movlw   0xff     ;0xff
         movwf   reg2
         movwf   reg1
	     movlw   0xff     ;0xff
L1:     decfsz  reg1
        goto    L1
        decfsz  reg2
        goto    L1
        decfsz  reg3
        goto    L1
        movf        w_temp,0
            return
After changing to,
delay500:
         movlw   0x04  ;0x04
         movwf   reg3
         movlw   0xff     ;0xff
         movwf   reg2
         movwf   reg1
L1:     decfsz  reg1
        goto    L1
        decfsz  reg2
        goto    L1
        decfsz  reg3
        goto    L1
            return
Now it is rolling.
  • led.rar
thanks for all
Have written a new program has benefited from your adviceز
