What is the difference between I2C and CAN
elec-eng
Full Member level 5
difference between can and i2c
please i want to know the difference between I2C and CAN
i know that both are used to interconnect microcontrollers
but also both of them has two wires
so what is the difference
deepu_ttc
Member level 5
different between i2c,spi and can protocol
both are same method of sending data except CAN is priorty based and it has data read back facility.
--pradeep
ariyan
Member level 5
difference between can and i2c ppt
I2C is a simple, well known, universally accepted, cost effective inter IC communication protocol. It has also plug & play feature with large portfolio and but main disadvantage is Limited speed.
Where CAN is a secure and FAST communication protocol. But CAN is expensive and a bit complex protocol. It is mainly automotive oriented with limited portfolio.
ShuklaS
Member level 1
difference between i2c and can
hi,
I2c and CAN both are use for serial communication this is only common thing,
the CAN is genraly used for device net (different device at different location)where as the I2c is genraly used in same PCB.
nitigon
Member level 1
difference between i2c and can protocols
hi hwo have good book for i2c program for picbasic
btbass
Advanced Member level 5
Oberon
difference between i2c and ethernet
To use CAN you need a tranceiver to convert the can tx and rx to a terminated low voltage differential signal pair. Termination is 120R at each end of the bus. CAN is a broadcast protocol, all nodes receive all messages. The messages can be filtered and masked by the hardware.
At the transport level it is fairly easy to use. Arbitration, priority, collision detection ect. is all taken care of by the hardware. Messages contain an ID, message type and up to 8 bytes of data.
But on top of this simple message structure have been built some complex and powerfull protocols used by the automotive industry.
nitigon
Member level 1
difference between i2c bus and can bus
can i2c communication mcu and mcu
kender
Stanford, SF Bay Peninsula, California, Earth, Sol
comparison between i2c and can
That's often, but not always the case. There are some automotive sensors that communicate over CAN. There are Serialli Linked I/O (SLIO) devices that act like ADC, DAC, I/O expanders and PWMs that are linked to the host inteligence via CAN.
Besides, I2C is used to communicate between uCs as well.
rachid77
Newbie level 6
diffrence between can and i2c protocal
hello
the first one is for output for signal ana/num
the seconde one is for trensfer for data.
regards.
funnynypd
Banned
USA & Canada
difference between can bus & i2c bus
One is from Phillips, and one is from BOSCH. Both are European company.
mImoto
Full Member level 4
differences between can and i2c
I2c it is mainly for intraboard PCB communication. Micro to I2C ADC, etc.
CAN is for communication between different equipment.
