Jan 6, 2005 #1 V vibhute_r_p Member level 1 Joined May 3, 2004 Messages 36 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,288 Activity points 229 HAs any one done any experimentation with pausable clocking? What does it mean? CAn you provide some VHDL or verilog code?
Jan 6, 2005 #2 N nand_gates Advanced Member level 3 Joined Jul 19, 2004 Messages 899 Helped 175 Reputation 350 Reaction score 53 Trophy points 1,308 Activity points 7,037 Hi, Using google search I got this!! www.ece.rochester.edu/~yozhu/ comparch-seminar/Clock_Synchronization.pdf Hope this helps
Jan 7, 2005 #3 Y yeewang Full Member level 2 Joined Feb 4, 2002 Messages 128 Helped 7 Reputation 14 Reaction score 2 Trophy points 1,298 Activity points 1,042 pausable clocking? simply that the clock can be paused and resumed without interfering logic operations, I think.
Jan 8, 2005 #4 F floatgrass Member level 3 Joined May 7, 2002 Messages 67 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,288 Activity points 517 always @ (posedge clk or negedge clear) if(!clear) clk_2 <= 0 ; else if(!en_n) clk_2 <= ~clk_2 ; else clk_2 <= clk_2 ;
