What is operating frequency of BD 139
deepakchikane
Full Member level 3
Full Member level 3
Mumbai, Maharashtra, India, India
Hi all,
i would like to know the operating frequency of BD 139.
I am generating 30 khz signal from a controller & driving a bjt bd 139 for current amplification purpose.
i have biased the bd 139 to maintain a voltage between B-E terminals.
but the bd 139 is giving a signal for more time than actual controller signal.
datasheet:https://www.st.com/web/en/resource/technical/document/datasheet/CD00001225.pdf
check the attached image
1) pink is the waveform from controller.(5v)
2) Blue waveform is at the actual bjt pin (gnd to base of bd 139)
biasing resistor is 400 ohms.
betwixt
Super Moderator
Staff member
Advanced Member level 7
Aberdyfi, West Wales, UK
The BD139 is good to much higher frequency, I have used them at 20MHz with no problems. It seems something is wrong with the circuit driving the base pin, can you post your schematic so we can see please.
Brian.
betwixt
Super Moderator
Staff member
Schematic please! Saying it's "like a switch" doesn't tell us anything. It appears that whatever drives the bias resistor is not able to sink current to remove that bias.
Brian.
chuckey
Advanced Member level 6
Southampton and holiday cottage in Wensleydale (UK
When the drive pulse appears the Vc falls on the transistor. When the base drive falls to 0V, the Vc rises and because of the internal capacitance of the transistor raises the base voltage. Try reducing the base driving impedance, to discharge this capacitance faster.
Frank
deepakchikane
Full Member level 3
Full Member level 3
Following experiments done with the bc 547.
here also there is time difference while going high to low.
this makes us problematic at 100 khz.
feedback/suggestions welcome.
Thanks
betwixt
Super Moderator
Staff member
I suspect your signal source has a relatively high impedance. What you are seeing is the effect of the capacitance of the base to emitter junction holding charge. It's a bit like adding a capacitor across the signal, it takes a short time to charge up and a slightly longer time to discharge. What you need is a path for that capacitance to discharge quickly so the voltage drops faster. In very high speed applications it isn't uncommon to see resistors of only a few Ohms between the base and emitter to ensure fast switching times. The problem obviously gets worse as the frequency increases but it should work at much higher speeds than 100KHz.
You have three options:
1. reduce the value of the base resistor even further and hope the signal source can sink more current when it is low and supply more when it is high.
2. add a resistor across the base and emitter to provide a discharge path but be aware this will also increase the drive current needed.
3. use an additional driver circuit to increase the available bias currents.
Brian.
E-design
Advanced Member level 5
You can also try to speed up the turn-off by adding a reverse diode. This will only be effective if the driving impedance is low enough.
E-design
This diode will work to many MHz no problem.
FvM
Super Moderator
Staff member
Bochum, Germany
The diode allone won't speed up transistor switching much (only quite a bit by working of it's junction capacitance) , you'll either need a negative input voltage or a capacitor parallel to the base resistor. A schottky diode would have a better effect.
E-design
By comparison, the diode appears to have a noticeable effect on the turn-off time similar to using a speed-up capacitor solution.
If the driving impedance is low enough, which seems not to be the case in his situation, the capacitor method could give better switching speeds if you are willing to accept possible edge spikes in the output waveform.
Here in the last plot it shows faster switching speed using the capacitor with driving impedance 25 Ohm.
FvM
Super Moderator
Staff member
Bochum, Germany
A small capacitor of s few 100 pF gives best results.To supress the negative output spike, add a series resistor of e.g. 100 ohm. But I agree that 1N4148 doesn't perform bad as well.
When designing a real circuit, we must look for the available generator source impedance.
E-design
I have found from experience that it takes a fairly large value of capacitance to have a worthwhile effect.
Here with a 100 pF capacitor and 25 Ohm driving impedance, there is almost no difference from using just the resistor.
