what is different signal and variable in vhdl?
u24c02
Advanced Member level 1
Hi.
When i have trying to use these signal and variable in vhdl, i dont know exactly different each of them.
What they have pros and cons and how can handle to use? Would you let me know?
You can refer any material on the net for this. Basically signal is global(throughout the architecture) while variable is local to the process it is defined in.
Also in a process signal assignments are scheduled whereas variable assignments are dome immediately.
Regards
There are three major difference between a signal and a variable in the VHDL
Coverage wise –
Signals has coverage to whole architecture, it can be access from any place in a Architecture of entity
A variable is local to a procedure defined in the architecture
Behavior wise –
Signal assignments executes concurrently, It means, if we have 5 signals assignment, then it depends on the simulator to decide which signal to be assigned first
In case of variable, it takes the value immediately OR in other language, it executes sequentially
Synthesis Wise –
If we have 2 variable and two signals used in a process, the variables infer just a wire during synthesis, but the signals infer a Flop.
