I install ic5033 and m@tlab 7 on my SUSE 10 with KDE Desktop. Sometimes, I got the problems like the m@tlab shuts down automatically while I am working on it. I also had a problem with pop-up menu on ic5033. Does KDE matter?
Moreover, I want to know about SUSE Enterprise version. Is it better than opensource version?
It shouldn't really matter. By the way, both Gnome and KDE don't really have a browser as mature as Firefox so you're probably best off using firefox under both environments. Regarding the SQL error, the sql statements / commands are executed on the server, so it has nothing to do with your Gnome or KDE configuration.
I have noticed myself, atleast with GNOME, that some screens/menus in IC5033 need the full screen res without top or bottom borders. But when using CDE (solaris), since there is no boarders, the menus display perfectly. I assume they were originally intended for CDE. As for KDE, I haven't used it, but if it has a floating control window like CDE, then KDE would be more appropriate.
I also use SuSE 10.0 Linux with KDE.
I have installed IC5033 and have no problems with it.
I think that problem is in some of your environment settings.
I've a time when I had problems with selecting pathes in dialogs, but I've solved this problem. The problem was in my LANG variable. (I also use Russian language in my system so all I've had to do is set LANG=C before useing cadence)
