What is a subroutine in C language?
subdural
Junior Member level 1
Neutral Zone
Hi
I'm newbie. I need to know what is the subroutine in C language?
For example I have C source code name main1.c as below;
main()
int a = 0x12345678, b;
b = endswap(a);
printf("Existing value in hex: %X\n", a);
printf("Endian-swapped value in hex: %X\n", b);
How to link the subroutine with other C source code named endswap.c
Thanks in addvanced
Re: subroutine in C
subroutines are called functions in C language.
in your code "endswap" & "printf" are functions (same as subroutines)
"printf" is a standard library function.
if you are using a any GUI including TC, you have to create a project and add all C files to the project. for example main.c and endswap.c
If you are using a commnadline compiler like gcc, you have to supply all files as arguments like
gcc main.c endswap.c "or"
gcc -test main.c endswap.c (here output exe/out file name will be test)
Cheers
idlebrain
    subdural
Re: subroutine in C
You can also put multiple C functions into one source file, like this:
#include <stdio.h>
int endswap(int x)
  return x*x;     /* or whatever you want to do */
int main(void)
  b = endswap(a);
  return 0;
    subdural
Re: subroutine in C
Hi Idlebrain,
Excellent information.
Since the subroutine is function in C, in main.c source code assume that a=0x12345678 is little-endian (memory) and how to program the subroutine in endswap.c source code so that the output b = 78563412 in big-endian.
Should I write as below; (I'm using arm-elf-gcc compiler)
endswap()
int a = 0x78563412, b;
b = endswap(a);
subroutine in C
I think you can put it by using include.
#include <endswap.c>
main()
b = endswap(a);
    subdural
Re: subroutine in C
here is the code. the endswap function converts little endian to big endian and vice versa.
It is very simple for understanding.
in endswap.c
int endswap(int number)
	unsigned char *bp1, *bp2;
	int rev;
	bp1 = (char *)&number;
	bp2 = (char *)&rev;
	bp2[0] = bp1[3];
	bp2[1] = bp1[2];
	bp2[2] = bp1[1];
	bp2[3] = bp1[0];
	return rev;
in main.c
#include <stdio.h>
int endswap(int); /* function prototype */
void main(void)
	int no = 0x12345678;
	printf("before = %X\n",no);
	no = endswap(no);
	printf("After  = %X\n",no);
Offcourse Yes, But it is not recomonded to include c files.
Cheers
idlebrain
    subdural
Re: subroutine in C
Hi Idle,
Appriecite you endswap function. However when I compile and link between main.c and endswap.c I got these errors. Could help me to solved it.
$ arm-elf-gcc main.c endswap.c -o assn3a.exe
endswap.c: In function `main':
endswap.c:20: warning: return type of 'main' is not `int'
/cygdrive/c/DOCUME~1/NAZRI~1.WAR/LOCALS~1/Temp/ccSgudxp.o(.text+0xa4): In functi
on `main':
: multiple definition of `main'
/cygdrive/c/DOCUME~1/NAZRI~1.WAR/LOCALS~1/Temp/ccswBXjg.o(.text+0x0): first defi
ned here
/cygdrive/c/program files/gnuarm/bin/../lib/gcc/arm-elf/3.4.3/../../../../arm-el
f/bin/ld: Warning: size of symbol `main' changed from 88 in /cygdrive/c/DOCUME~1
/NAZRI~1.WAR/LOCALS~1/Temp/ccswBXjg.o to 80 in /cygdrive/c/DOCUME~1/NAZRI~1.WAR/
collect2: ld returned 1 exit status
Re: subroutine in C
May be the return type of main startup code is defined as int.
Try this in main.c file.
#include <stdio.h>
int main(void)
   no = endswap(no);
   return 0;
If it is not working first try a simple hello world
program.
    subdural
Re: subroutine in C
Hi Idlebrain,
Good job! I managed to compile and get the expected output. However, could you explain how this function operate/work? Thanks
Re: subroutine in C
The Basics
"Little Endian" means that the low-order byte of the number is stored in memory at the lowest address, and the high-order byte at the highest address. (The little end comes first.) For example, a 4 byte LongInt
Byte3 Byte2 Byte1 Byte0
will be arranged in memory as follows:
Base Address+0 Byte0
Base Address+1 Byte1
Base Address+2 Byte2
Base Address+3 Byte3
Intel processors (those used in PC's) use "Little Endian" byte order.
"Big Endian" means that the high-order byte of the number is stored in memory at the lowest address, and the low-order byte at the highest address. (The big end comes first.) Our LongInt, would then be stored as:
Base Address+0 Byte3
Base Address+1 Byte2
Base Address+2 Byte1
Base Address+3 Byte0
Motorola processors (those used in Mac's) use "Big Endian" byte order.
The Algorithm
as per the above expl, we need to swap the bytes as follows
BA+0 to BA+3,BA+1 to BA+2,BA+2 to BA+1,BA+3 to BA+0.
This is done by taking two char(byte) pointers bp1 = BA of actual endian, bp2 = BA of other endian. Now byte locations are swaped as required.
I hope it is clear.
idlebrain
    subdural
Re: subroutine in C
Hi
Good information and self explanation. However the endswap function seem like array.
