what equipment i need for TV workshop?
manossk
Newbie level 1
TV WORKSHOP
Hi, to you all
Pls can anyone tell me what equipment i need for TV workshop ?
many thanks in advance
Hi, i think you need this, Digital meter,Freq meter , Osciloscope,soldering iron,suckers,soldering lead,set's of screw drivers,lamp,cutters& plairs,working bench,power supplys,
a multimeter and soldering iron, solder wick
Dont forget:
HV meter,
TV-Signal or colorbar generator:)
Tube tester...
K.
Digital multimeter, Osciloscope, soldering iron, suckers, soldering lead, set's of screw drivers, cutters& plairs, test set
are you going to open a tv workshop? you actually need more spare part.. i used to work in sharp r&d audio video department
karesz said:
Dont forget:HV meter, TV-Signal or colorbar generator:)
Tube tester...K.
Add a hand held degausing coil too....Cheers
The most important thing you need is service manuals and contacts to get parts from.
An adjustable power supply, oscilloscope and multimeter plus some hand tools suffice. Forget about high voltage anything.
Externet said:
...Forget about high voltage anything.
Why pls?
Todays TVs dont needs/works with HV?
K.
