What does repeated START bit do in I2C protocol?
verilog_always
Member level 2
Member level 2
Hi all,
In this protocal if no ACk is sent Master can send STOP bit or Repeated START bit. What does repeated START bit do? Whether it Master has again Start from Scratch that is sending address of slave and so on?
Re: I2C protocal doubt
Master can send repeated start bit in stead of stop bit. the conditions for start and repeated start are same. master has to send the slave address again. at the end of the transfer master has to send stop bit or again repeated start bit.
I2C protocal doubt
When a slave doesn’t acknowledge the slave address (for
example, it’s unable to receive or transmit because it’s
performing some real-time function), the data line must be
left HIGH by the slave. The master can then generate
either a STOP condition to abort the transfer, or a repeated
START condition to start a new transfer.
LaTeX Commands Quick-Menu:
