poorren
Junior Member level 3
Hello,
I'm building a frequency synthesiser using a national semi's PLL. Because, the VCO's tuning voltage is out of the range of PLL power supply. I choose to use a type A active filter as attachment.
I used National semi's easyPLL to get a loop filter with 3order, and test it in real circuit. I found the voltage of CP (directly connected to OP AMP -) is almost 3.3V, the power supply of PLL, the voltage bias on OP AMP + input has been set to 1.9V. Using Osc Scope, I capture the voltage waveform of CP output, the voltage has short pulse constantly. The pulse has a min voltage 2.8V, max voltage 3.3V. So, I am very confused that what kind of things determinate the voltage of CP? How the current output of CP change to tuning voltage at VCO?
Thanks for your replies and time.
