What are bitwise operators in C used for ?
saudrehman
Member level 1
Member level 1
can anybody explain the use of Bitwise operators like and,or,exor in C programming for microcontrollers.
Re: bitwise operators in C
you can read it in book programming for C.
Exp: "and"
1&1=1
1&0=0
0&1=0
0&0=0
note that when you bitwise and (or, xor), each bit is anded (ored, xored) with the correspoding bit in the other word.
so 0b1010 & 0b1100 becomes 0b1000
or in hex 0xA & 0xC becomes 0x8
and is great for masking/clearing bits - say you want to zero all but the last three bits in a byte, call it val.
val = val & 0x7;
or is good for setting bits. for example, setting pins to input (1) or output (0):
TRISB = TRISB | 0b00011100; // sets pins 2, 3 & 4 to input, leave the others alone
I prefer to use binary repersentation when fiddling with bits in registers. makes it alot clear what's going on.
Phil
hi
this may help u
Bitwise Operators:
Operators that work on the individual bits within a variable are
called bitwise operators. Following is a table of all of these operators:
& bitwise AND
| bitwise Inclusive OR
^ bitwise Exclusive OR
~ one’s complement.
>> right shift
<< left shift
more details u can find in any c book
the forum EDA E-books Upload/Download has many c books, just search
salam
Ahmed
www.i-g.org
i need a help on the same bitwise operations.
but this a little complicated. this is bitwise copying and pasting.
i need to copy a particular number of bits and paste at different loaction.
eg., A stream has 1000 bits. i am copying from 102 bit to 201 bit, then pasting(overwriting) at 305 th bit. is there an algorithm to do this.
regards,
shanmugavel
shanmugavel this is totally different subject.First we need to know how your 1000 bit stream is organized in the memory?
hi if I wont to write 0b 00001010 to a memmery that holds 0bxxxx0000 and I dont wont to overwrite "x" data on the memmery and I don't know wot these x binary holds. how do I do? i C programming
