WDT timer on the PIC16F687
M3GAPL3X
Junior Member level 3
wdt timer
Hi guys,
In the spec sheet, it says that the WDT has a:
Time-out period is from 1 ms to 268 seconds
I can't figure out how this is true with the given post-scalar values of the WDT timer.
Here are the values of WDTCON:
WDTPS<3:0>: Watchdog Timer Period Select bits
Bit Value = Prescale Rate
0000 = 1:32
0001 = 1:64
0010 = 1:128
0011 = 1:256
0100 = 1:512 (Reset value)
0101 = 1:1024
0110 = 1:2048
0111 = 1:4096
1000 = 1:8192
1001 = 1:16384
1010 = 1:32768
1011 = 1:65536
1100 = reserved
1101 = reserved
1110 = reserved
1111 = reserved
If anyone can tell me how I can get 1 ms or 268 seconds from those values, it would be greatly appreciated! The 18f series was more straight forward.
In the spec sheet it says that Enhanced Low-Current Watchdog Timer (WDT)
with On-Chip Oscillator (Software selectable
nominal 268 Seconds with Full Prescaler) with
Software Enable
set timer pic16f687
That's because it allows you to use the Timer0 prescaler as an 8-bit WDT post-scaler - see the path highlighted in red on the attached image.
pic16f687
Thanks GSM for your patience. That charge really helped!
LaTeX Commands Quick-Menu:
