Warning but doesn't seem to be enforced...
DarkInsanePyro
Newbie level 5
Hey guys so my semester is wrapping up and fortunately I have gotten all of the projects for the class done. Now this is a simple question. Xilinx is issuing a warning but it doesn't seem to be enforcing what it says. More specifically I have no idea why it is even stating it in the first place. The optimization warnings make sense since I zero-extend the inputs from 4-bit to 8-bit and it can just optimize away 4 bits of the bus. What I am wondering about is the first warning where u1's output seems to be disconnected. Simulation is proving that this system works fine though. I just want to make sure there isn't any issue I am overseeing because if it was really disconnected my project wouldn't work at all. I haven't had the opportunity to test on hardware yet and unfortunately due to other classes clashing on time I will be testing on the due date (terrible I know). So I'll find out then. I don't see why it wouldn't... simulation likes the setup.
--# FullAdder
library ieee;
use ieee.std_logic_1164.all;
entity FullAdder is
	port(
		-- inputs
		A, B, Cin		:	in		std_logic;
		-- outputs
		Q, Cout			:	out	std_logic
end FullAdder;
architecture FullAdder_RTL of FullAdder is
begin
	Q <= A xor B xor Cin;
	Cout <= (A and B) or (A and Cin) or (B and Cin);
end FullAdder_RTL;
--# Adder
--# Width: 8-Bit
library ieee;
entity Adder is
	generic(
		Width				:	integer := 8
	port(
		-- inputs
		A, B				:	in		std_logic_vector(Width-1 downto 0);
		Cin				:	in		std_logic;
		-- outputs
		Q					:	out	std_logic_vector(Width-1 downto 0);
		CarryBus			:	out	std_logic_vector(Width downto 0);
end Adder;
architecture Adder_RTL of Adder is
	signal int_carry : std_logic_vector(Width downto 0);
	signal int_result : std_logic_vector(Width-1 downto 0);
	component FullAdder port (A,B,Cin : in std_logic; Q,Cout : out std_logic); end component;
begin
	int_carry(0) <= Cin;
	gen: for i in Width-1 downto 0 generate
		fa:	FullAdder port map(A=>A(i), B=>B(i), Cin=>int_carry(i), Q=>int_result(i), Cout=>int_carry(i+1));
	end generate;
	Q <= int_result;
	Cout <= int_carry(int_carry'left);
	CarryBus <= int_carry;
end Adder_RTL;
--# DataBuffer (Register)
--# Width: 8-Bit
--# Reset: Async
library ieee;
entity DataBuffer is
	port(
		-- inputs
		D				:	in		std_logic_vector(7 downto 0);
		Clk			:	in		std_logic;
		Rst			:	in		std_logic;
		-- outputs
		Q				:	out	std_logic_vector(7 downto 0)
end DataBuffer;
architecture DataBuffer_RTL of DataBuffer is
	signal state	:	std_logic_vector(7 downto 0);
begin
	process (D,Clk,Rst)
	begin
		if (Rst = '1') then
			state <= (others => '0');
		elsif (Clk'event and Clk = '1') then
			state <= D;
		end if;
	end process;
	Q <= state;
end architecture;
--# Accumulator
--# Width:	8-Bit
--# Clock:	Rising Edge
--# Reset:	Async
library ieee;
use ieee.numeric_std.all;
entity Accumulator is
	port(
		-- inputs
		Clk			:	in		std_logic;
		Rst			:	in		std_logic;
		-- outputs
end Accumulator;
architecture Accumulator_RTL of Accumulator is
	-- required components
	component Adder is port (
		A					:	in		std_logic_vector(7 downto 0);
		B					:	in		std_logic_vector(7 downto 0);
		Cin				:	in		std_logic;
		Q					:	out	std_logic_vector(7 downto 0);
		CarryBus			:	out	std_logic_vector(8 downto 0);
	end component;
	-- internal signals
	signal value		:	std_logic_vector(7 downto 0) := (others => '0');
	signal next_value	:	std_logic_vector(7 downto 0);
begin
	-- components
	u1:	Adder port map (A=>value, B=>D, Cin=>'0', Q=>next_value);
	-- logic
	process (D,Clk,Rst)
	begin
		if (Rst = '1') then
			value <= (others => '0');
			--value <= std_logic_vector(unsigned(value) + unsigned(D));
			value <= next_value;
		end if;
	end process;
	Q <= value;
end architecture;
--# ZeroDetect
--# Width: 8-Bit
library ieee;
entity ZeroDetect is
	port(
		-- inputs
		-- outputs
		Z				:	out	std_logic
end ZeroDetect;
architecture ZeroDetect_RTL of ZeroDetect is
begin
	Z <= not (D(0) or D(1) or D(2) or D(3) or D(4) or D(5) or D(6) or D(7));
end architecture;
--# Decrementer
--# Width:	8-Bit
--# Clock:	Falling Edge
library ieee;
entity Decrementer is
	port(
		-- inputs
		Load			:	in		std_logic;
		Clock			:	in		std_logic;
		-- outputs
		Z				:	out	std_logic
end Decrementer;
architecture Decrementer_RTL of Decrementer is
		Cin			:	in		std_logic;
	end component;
	component ZeroDetect is port (
		Z				:	out	std_logic
	end component;
	-- internal signals
	signal value			:	std_logic_vector(7 downto 0);
	signal dec_value		:	std_logic_vector(7 downto 0);
begin
	-- logic
	process (Load, Clock, D)
	begin
		if (Load'event and Load = '1') then
			value <= D;
		elsif (Clock'event and Clock = '0') then
			value <= dec_value;
		end if;
	end process;
	-- components
	u1:	Adder port map (A=>value, B=>"11111111", Cin=>'0', Q=>dec_value);
	u2:	ZeroDetect port map (D=>value, Z=>Z);
	Q <= value;
end architecture;
--# Multiplier
--# Width:	4-Bit x 4-Bit = 8-Bit
--# Start:	Rising Edge
--# Load:	Rising Edge
--# Clear:	Async
library ieee;
entity Multiplier is
	port(
		-- inputs
		A				:	in		std_logic_vector(3 downto 0);
		B				:	in		std_logic_vector(3 downto 0);
		Start			:	in		std_logic;
		Clear			:	in		std_logic;
		-- outputs
		Product		:	out	std_logic_vector(7 downto 0);
		Run			:	out	std_logic
end Multiplier;
architecture Multiplier_RTL of Multiplier is
	-- Predefined Entities
	component DataBuffer port (
		Clk, Rst	:	in		std_logic;
	end component;
	component Accumulator port (
		Clk		:	in		std_logic;
		Rst		:	in		std_logic;
	end component;
	component Decrementer port (
		Z			:	out	std_logic
	end component;
	-- Internal Signals
	signal a_extended	:	std_logic_vector(7 downto 0);
	signal b_extended	:	std_logic_vector(7 downto 0);
	signal a_value		:	std_logic_vector(7 downto 0);
	signal b_value		:	std_logic_vector(7 downto 0);
	signal run_clock	:	std_logic;
	signal b_zero		:	std_logic;
	signal running		:	std_logic := '0';
begin
	-- components
	u1:	DataBuffer port map (D=>a_extended, Clk=>Load, Rst=>'0', Q=>a_value);
	u2:	Decrementer port map (D=>b_extended, Load=>Load, Clock=>run_clock, Z=>b_zero);			-- falling edge clocked
	u3:	Accumulator port map (D=>a_value, Clk=>run_clock, Rst=>Clear, Q=>Product);					-- rising edge clocked
	-- logic
	run_clock <= Clock and (not b_zero) and running;		-- only run for as long there is a value in B
	a_extended <= "0000" & A;
	b_extended <= "0000" & B;
	process (b_zero, running, Start, Clock)
	begin
		-- start the process if:
		-- 1. Start signal asserted (rising edge)
		-- 2. Latched B value is larger than zero.
		if (Start'event and Start = '1' and (b_zero = '0')) then
			running <= '1';
		end if;
		-- stop the process if
		-- 1: B value is zero
		if (Clock = '0' and (b_zero = '1')) then
			running <= '0';
		end if;
	end process;
	Run <= running;
end architecture;
WARNING:Xst:2972 - "C:\Users\DarkPrince\Documents\Xilinx Projects\ClockedMultiplier\ClockedMultiplier.vhd" line 254. All outputs of instance <u1> of block <Adder> are unconnected in block <Decrementer>. Underlying logic will be removed.
WARNING:Xst:647 - Input <Clock> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:1710 - FF/Latch <state_4> (without init value) has a constant value of 0 in block <u1>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <state_5> (without init value) has a constant value of 0 in block <u1>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <state_6> (without init value) has a constant value of 0 in block <u1>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <state_7> (without init value) has a constant value of 0 in block <u1>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <value_4> (without init value) has a constant value of 0 in block <u2>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <value_5> (without init value) has a constant value of 0 in block <u2>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <value_6> (without init value) has a constant value of 0 in block <u2>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <value_7> (without init value) has a constant value of 0 in block <u2>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <state_4> (without init value) has a constant value of 0 in block <DataBuffer>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <value_4> (without init value) has a constant value of 0 in block <Decrementer>. This FF/Latch will be trimmed during the optimization process.
The problems may be related to this non-synthesizable statement:
  value <= D;
  value <= dec_value;
end if;
I don't know why it doesn't create a warning or synthesis error on it's own. The construct refers to a FF with two clocks, which doesn't exist in any known programmable logic device.
You are absolutely correct. I am also surprised it never complained and went straight though "Implement Design" without any issues. I really feel that VHDL is strongly typed but then Xilinx breaks that by not checking all aspects of the design being implemented for hardware. So what it actually generated, not sure. Anyway, I converted that over to a synchronous load and it started working in that aspect. Now another issue with delaying the clock signal. Probably just another silent failure...
It's not exactly a VHDL problem. VHDL has no principle problems to model a FF with multiple clocks. But it's not synthesizable in usual hardware.
Altera Quartus doesn't compile similar constructs and gives an understandable error message about the reason. According to your observations, Xilinx seems to ignore the second clock edge and remove the respective logic. Of course warnings of this kind shouldn't be ignored, but a synthesis error would be appropriate, I think.
