[SOLVED] One of my input Values Seem to Be Changing as I Pass it into a Port
kvnsmnsn
Junior Member level 1
I am at a loss as to why my piece of Verilog code isn't working. The general idea of my code is that I have up to six queues, three "down" and three "up," and given a side (determined by value (loadingUp)), I'm trying to find which queue on that side has the least value at its head. My testbench passes (2'b10) and (2'b00) into values (hdUm) and (hdDm) respectively in my (sPivots) module. But if I immediately assign debugging values (d_hdUm) and (d_hdDm) respectively to those two inputs and return them as outputs, I get a value of (zz) for each of them. I checked my Verilog (that I'm attaching), and I don't do anything with (hdUm) or (hdDm) except pass them as inputs into my (MuOuNmx) module. How are these two values getting changed? Any pointers on this would be greatly appreciated.
My (sPivots) module (with all the modules it uses inserted) is:
// (c) Kevin Simonson 2025
module Nt ( output rslt
          ,  input op);
  supply0 ground;
  supply1 power;
  nmos n( rslt, ground, op);
  pmos p( rslt, power , op);
endmodule
module Nd2 ( output rslt
           ,  input aOp
           ,        bOp);
  supply0 ground;
  supply1 power;
  wire    srCn;
  nmos na( srCn, ground, aOp);
  nmos nb( rslt, srCn  , bOp);
  pmos pa( rslt, power , aOp);
  pmos pb( rslt, power , bOp);
endmodule
module Nr2 ( output rslt
           ,  input aOp
           ,        bOp);
  supply0 ground;
  supply1 power;
  wire    srCn;
  nmos na( rslt, ground, aOp);
  nmos nb( rslt, ground, bOp);
  pmos pa( srCn, power , aOp);
  pmos pb( rslt, srCn  , bOp);
endmodule
module Nmx2 ( output rslt
            ,  input pLow
            ,        pHgh
            ,        dLow
            ,        dHgh);
  wire mux;
  nmos nl( mux , dLow, pLow);
  pmos pl( mux , dLow, pHgh);
  nmos nh( mux , dHgh, pHgh);
  pmos ph( mux , dHgh, pLow);
  Nt    t( rslt, mux);
endmodule
module MuOuNmx #(            nmBits = 2
                , localparam maxBit = nmBits - 1)
              ( output [ maxBit:0] rslt
              , input              pHgh
              ,                    pLow
              ,        [ maxBit:0] dHgh
              ,        [ maxBit:0] dLow);
  genvar bt;
  generate
    for (bt = 0; bt < nmBits; bt = bt + 1)
    begin
      Nmx2 m( rslt[ bt], pHgh, pLow, dHgh[ bt], dLow[ bt]);
    end
  endgenerate
endmodule
module LessThan #(            kyBits  = 2
                 , localparam keyHigh = kyBits - 1)
               ( output              rslt
               ,  input [ keyHigh:0] lssr
               ,        [ keyHigh:0] grtr);
  assign rslt = lssr < grtr;
endmodule
module sPivots #(            kyBits   = 2
                ,            nmQueues = 6
              ( output              chsLf
              ,                     chsMd
              ,                     chsRg
, [ keyHigh:0] d_hdDm
, [ keyHigh:0] d_hdUm
              ,  input              loadingUp
              ,        [ keyHigh:0] hdUl
              ,        [ keyHigh:0] hdUm
              ,        [ keyHigh:0] hdUr
              ,        [ keyHigh:0] hdDl
              ,        [ keyHigh:0] hdDm
              ,        [ keyHigh:0] hdDr);
  wire              lfLtMd, lfLtRg, mdLtRg;
  wire [ keyHigh:0] ntHdLf, ntHdMd, ntHdRg;
  wire              loadingDown;
  wire              ntChsLf;
  wire              mdGeRg;
  wire              lfGeMd;
  wire              ldAndLlm;
  wire              lfGeRg;
  wire              ldAndLlr;
  Nt aT( loadingDown, loadingUp);
  Nt bT( mdGeRg, mdLtRg);
  generate
    if (4 < nmQueues)
    begin
      MuOuNmx #( kyBits) lMu( ntHdLf, loadingUp, loadingDown, hdDl, hdUl);
      MuOuNmx #( kyBits) mMu( ntHdMd, loadingUp, loadingDown, hdDm, hdUm);
assign d_hdDm = hdDm;
assign d_hdUm = hdUm;
      LessThan #( kyBits) lmL( lfLtMd, ntHdMd, ntHdLf);
      LessThan #( kyBits) lrL( lfLtRg, ntHdRg, ntHdLf);
      Nd2 cD( ntChsLf, lfLtMd, lfLtRg);
      if (nmQueues == 6)
      begin
        Nt  dT( chsLf, ntChsLf);
        Nr2 eR( chsMd, lfLtMd, mdGeRg);
        Nr2 fR( chsRg, lfLtRg, mdLtRg);
      end
      else
      begin
        Nr2 gR( chsLf, loadingUp, ntChsLf);
        Nt  hT( lfGeMd, lfLtMd);
        Nr2 iR( ldAndLlm, loadingUp, lfGeMd);
        Nr2 jR( chsMd, ldAndLlm, mdGeRg);
        Nt  kT( lfGeRg, lfLtRg);
        Nr2 lR( ldAndLlr, loadingUp, lfGeRg);
        Nr2 mR( chsRg, ldAndLlr, mdLtRg);
      end
    end
    else
    begin
      assign chsLf = 1'b0;
      Nr2 nR( chsMd, loadingUp, mdGeRg);
      Nd2 oD( chsRg, loadingDown, mdLtRg);
    end
  endgenerate
  MuOuNmx #( kyBits) rMu( ntHdRg, loadingUp, loadingDown, hdDr, hdUr);
  LessThan #( kyBits) mrL( mdLtRg, ntHdRg, ntHdMd);
endmodule
// if      nmQueues == 6 then
//   chsLf = ~ ( ~ (lfLtMd & lfLtRg))
//   chsMd = ~ (lfLtMd | ~ mdLtRg)
//   chsRg = ~ (lfLtRg | mdLtRg)
// else if nmQueues == 5 then
//   chsLf = ~ (loadingUp | ~ (lfLtMd & lfLtRg))
//   chsMd = ~ (~ (loadingUp | ~ lfLtMd) | ~ mdLtRg)
//   chsRg = ~ (~ (loadingUp | ~ lfLtRg) | mdLtRg)
// else if nmQueues == 3 then
//   chsLf = 0
//   chsMd = ~ (loadingUp | ~ mdLtRg)
//   chsRg = ~ (loadingDown & mdLtRg)
My testbench is:
module t23_sPivots_Bug;
  reg         ldngUp;
  reg  [ 1:0] hdUl;
  reg  [ 1:0] hdUm;
  reg  [ 1:0] hdUr;
  reg  [ 1:0] hdDl;
  reg  [ 1:0] hdDm;
  reg  [ 1:0] hdDr;
  wire        chsLf;
  wire        chsMd;
  wire        chsRg;
wire [ 1:0] d_hdDm, d_hdUm;
  sPivots #( 2, 3)
          p( chsLf, chsMd, chsRg
, d_hdDm, d_hdUm
, ldngUp, hdUl, hdUm, hdUr, hdDl, hdDm, hdDr);
  initial
  begin
       ldngUp = 1'b0;
       hdUl = 2'b00; hdUm = 2'b10; hdUr = 2'b10;
       hdDl = 2'b00; hdDm = 2'b00; hdDr = 2'b00;
    #3 $finish;
  end
  always @( ldngUp, hdUl, hdUm, hdUr, hdDl, hdDm, hdDr, chsLf, chsMd, chsRg)
  begin
    $display
      ( "t: %2t, lu: %1b, ul: %2b, um: %2b, ur: %2b, dl: %2b, dm: %2b, dr: %2b"
      , $time  , ldngUp , hdUl   , hdUm   , hdUr   , hdDl   , hdDm   , hdDr);
    $display( "          cl: %1b, cm: %1b, cr: %1b", chsLf, chsMd, chsRg);
$display( "hdDm: %2b, hdUm: %2b", d_hdDm, d_hdUm);
  end
endmodule
And the results when I run this on EDA Playground are:
Parsing design file 'design.sv'
Parsing design file 'testbench.sv'
Top Level Modules:
       t23_sPivots_Bug
TimeScale is 1 ns / 1 ns
Starting vcs inline pass...
1 module and 0 UDP read.
recompiling module t23_sPivots_Bug
rm -f _cuarc*.so _csrc*.so pre_vcsobj_*.so share_vcsobj_*.so
if [ -x ../simv ]; then chmod a-x ../simv; fi
g++  -o ../simv      -rdynamic  -Wl,-rpath='$ORIGIN'/simv.daidir -Wl,-rpath=./simv.daidir -Wl,-rpath=/apps/vcsmx/vcs/U-2023.03-SP2/linux64/lib -L/apps/vcsmx/vcs/U-2023.03-SP2/linux64/lib  -Wl,-rpath-link=./   objs/amcQw_d.o   _331_archive_1.so   SIM_l.o       rmapats_mop.o rmapats.o rmar.o rmar_nd.o  rmar_llvm_0_1.o rmar_llvm_0_0.o            -lvirsim -lerrorinf -lsnpsmalloc -lvfs    -lvcsnew -lsimprofile -luclinative /apps/vcsmx/vcs/U-2023.03-SP2/linux64/lib/vcs_tls.o   -Wl,-whole-archive  -lvcsucli    -Wl,-no-whole-archive          /apps/vcsmx/vcs/U-2023.03-SP2/linux64/lib/vcs_save_restore_new.o -ldl  -lc -lm -lpthread -ldl
../simv up to date
CPU time: .363 seconds to compile + .266 seconds to elab + .296 seconds to link
Chronologic VCS simulator copyright 1991-2023
Contains Synopsys proprietary information.
Compiler version U-2023.03-SP2_Full64; Runtime version U-2023.03-SP2_Full64;  Feb  8 19:29 2025
t:  0, lu: 0, ul: 00, um: 10, ur: 10, dl: 00, dm: 00, dr: 00
          cl: 0, cm: x, cr: x
hdDm: zz, hdUm: zz
$finish called from file "testbench.sv", line 26.
$finish at simulation time                    3
           V C S   S i m u l a t i o n   R e p o r t
Time: 3 ns
CPU Time:      0.350 seconds;       Data structure size:   0.0Mb
Sat Feb  8 19:29:34 2025
Done
Please let me know if you can see anything that I'm doing wrong.
--- Updated ---
Never mind! I figured out what I was doing wrong.
if the problem is solved --> press the [Mark as Solved] button
Klaus
