[SOLVED] Trying to Figure Out how to Test for Timing
kvnsmnsn
Junior Member level 1
I've got a piece of Verilog that calculates (aOp*bOp+cOp):
module Tf ( output rslt
          ,  input aOp
          ,        bOp
          ,        cOp);
  supply0 ground;
  supply1 power;
  wire    a_b;
  wire    ab_c;
  nmos na( a_b , ground, aOp);
  nmos nb( rslt, a_b   , bOp);
  nmos nc( rslt, ground, cOp);
  pmos pa( ab_c, power , aOp);
  pmos pb( ab_c, power , bOp);
  pmos pc( rslt, ab_c  , cOp);
endmodule
How do I check for timing, assuming that the delay of each nmos is 2 time units and the delay for each pmos is 2 time units? I tried writing:
  #2 nmos na( a_b , ground, aOp);
  #2 nmos nb( rslt, a_b   , bOp);
  #2 nmos nc( rslt, ground, cOp);
  #2 pmos pa( ab_c, power , aOp);
  #2 pmos pb( ab_c, power , bOp);
  #2 pmos pc( rslt, ab_c  , cOp);
but the compiler doesn't like that. My test code is:
// (c) Kevin Simonson 2025
module t_Tf;
  reg  aOp;
  reg  bOp;
  reg  cOp;
  wire rslt;
  Tf f( rslt, aOp, bOp, cOp);
  initial
  begin
        aOp = 1'b0; bOp = 1'b0; cOp = 1'b0;
    #10                         cOp = 1'b1;
    #10             bOp = 1'b1; cOp = 1'b0;
    #10                         cOp = 1'b1;
    #10 aOp = 1'b1; bOp = 1'b0; cOp = 1'b0;
    #10                         cOp = 1'b1;
    #10                         cOp = 1'b1;
    #10 $finish;
  end
  always @( aOp, bOp, cOp, rslt)
  begin
    $display
      ( "t: %2t, aOp: %1b, bOp: %1b, cOp: %1b"
      , $time  , aOp     , bOp     , cOp);
  end
endmodule
I'd just like to figure out how I can test the timing on this.
--- Updated ---
          ,  input aOp
          ,        bOp
          ,        cOp);
  supply0 ground;
  supply1 power;
  wire    a_b;
  wire    ab_c;
endmodule
module t_Tf;
  reg  aOp;
  reg  bOp;
  reg  cOp;
  wire rslt;
  initial
  begin
    #10                         cOp = 1'b1;
    #10                         cOp = 1'b1;
    #10                         cOp = 1'b1;
    #10                         cOp = 1'b1;
    #10 $finish;
  end
  begin
    $display
  end
endmodule
Oops! I meant it calculates ((aOp*bOp+cOp)'), and the test code is actually:
module t_Tf;
  reg  aOp;
  reg  bOp;
  reg  cOp;
  wire rslt;
  initial
  begin
    #10                         cOp = 1'b1;
    #10                         cOp = 1'b1;
    #10                         cOp = 1'b1;
    #10                         cOp = 1'b1;
    #10 $finish;
  end
  begin
    $display
      ( "t: %2t, aOp: %1b, bOp: %1b, cOp: %1b, rslt: %1b"
      , $time  , aOp     , bOp     , cOp     , rslt);
  end
endmodule
Sorry for the typos!
I did some experimenting with my code and came up with:
          ,  input aOp
          ,        bOp
          ,        cOp);
  supply0 ground;
  supply1 power;
  wire    a_b;
  wire    ab_c;
  nmos #2 na( a_b , ground, aOp);
  nmos #2 nb( rslt, a_b   , bOp);
  nmos #2 nc( rslt, ground, cOp);
  pmos #2 pa( ab_c, power , aOp);
  pmos #2 pb( ab_c, power , bOp);
  pmos #2 pc( rslt, ab_c  , cOp);
endmodule
This worked just fine so it would appear that my problem is fixed.
LaTeX Commands Quick-Menu:
