Vsim error 3807 types do not match between component and entity for port "ici"
abu9022
Member level 3
Member level 3
Hi Friends
I have error while running the command "vsim -sdfmax /tb_msp/p0=verilog_iu_syn.sdf tb_msp"
ERROR
# vsim -sdfmax /tb_msp/p0=verilog_iu_syn.sdf tb_msp
# Loading std.standard
# Loading ieee.std_logic_1164(body)
# Loading work.target
# Loading ieee.std_logic_arith(body)
# Loading work.device
# Loading std.textio(body)
# Loading work.config
# Loading work.mmuconfig
# Loading work.sparcv8
# Loading work.iface
# Loading work.leonlib
# Loading work.tb_msp(behav)
# Loading work.tech_map
# Loading ieee.std_logic_unsigned(body)
# Loading work.debug(body)
# Loading work.leon(rtl)
# Loading work.amba
# Loading work.ambacomp
# Loading work.mcore(rtl)
# Loading work.rstgen(rtl)
# Loading work.ahbarb(rtl)
# Loading work.apbmst(rtl)
# Loading work.fpulib
# Loading work.proc(rtl)
# Loading work.iu(syn_verilog)
# ** Failure: (vsim-3807) Types do not match between component and entity for port "ici".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 9
# ** Failure: (vsim-3807) Types do not match between component and entity for port "ico".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 10
# ** Failure: (vsim-3807) Types do not match between component and entity for port "dci".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 11
# ** Failure: (vsim-3807) Types do not match between component and entity for port "dco".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 12
# ** Failure: (vsim-3807) Types do not match between component and entity for port "fpui".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 13
# ** Failure: (vsim-3807) Types do not match between component and entity for port "fpuo".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 14
# ** Failure: (vsim-3807) Types do not match between component and entity for port "iui".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 15
# ** Failure: (vsim-3807) Types do not match between component and entity for port "iuo".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 16
# ** Failure: (vsim-3807) Types do not match between component and entity for port "rfi".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 17
# ** Failure: (vsim-3807) Types do not match between component and entity for port "rfo".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 18
# ** Failure: (vsim-3807) Types do not match between component and entity for port "cpi".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 19
# ** Failure: (vsim-3807) Types do not match between component and entity for port "cpo".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 20
# ** Failure: (vsim-3807) Types do not match between component and entity for port "fpi".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 21
# ** Failure: (vsim-3807) Types do not match between component and entity for port "fpo".
#    Time: 0 ps  Iteration: 0  Instance: /tb_msp/p0/mcore0/proc0/iu0 File: /mnt/iscsi/Users/ee5113/zxv764/oldiu/leon2-1.0.30-xst/leon/iu.vhd Line: 22
while I check the definition of error, it defined as " types of the port on the entity does not match the type of the port on the component which instantiates it"
proc.vhd(Instantiated file)
library IEEE;
use IEEE.std_logic_1164.all;
use work.target.all;
use work.config.all;
use work.mmuconfig.all;
use work.iface.all;
use work.amba.all;
use work.fpulib.all;
use work.tech_map.all;
entity proc is
  port (
    rst    : in  std_logic;
    clk    : in  clk_type;                      -- main clock
    clkn   : in  clk_type;                      -- inverted main clock
    apbi   : in  apb_slv_in_type;
    apbo   : out apb_slv_out_type;
    ahbi   : in  ahb_mst_in_type;
    ahbo   : out ahb_mst_out_type;
    ahbsi  : in  ahb_slv_in_type;
    iui    : in  iu_in_type;
    iuo    : out iu_out_type
end;
library IEEE;
use work.iface.all;
use work.amba.all;
architecture rtl of proc is
component iu
port (
    rst    : in  std_logic;
    clk    : in  clk_type;
    holdn  : in  std_logic;
    ici    : out icache_in_type;                -- icache input
    ico    : in  icache_out_type;               -- icache output
    dci    : out dcache_in_type;                -- dcache input
    dco    : in  dcache_out_type;               -- dcache output
    fpui   : out fpu_in_type;                   -- FPU input
    fpuo   : in  fpu_out_type;                  -- FPU output
    iui    : in  iu_in_type;                    -- system input
    iuo    : out iu_out_type;                   -- system output
    rfi    : out rf_in_type;                    -- register-file input
    rfo    : in rf_out_type;                    -- register-file output
    cpi    : out cp_in_type;                    -- CP input
    cpo    : in  cp_out_type;                   -- CP output
    fpi    : out cp_in_type;                    -- FP input
    fpo    : in  cp_out_type                    -- FP output
end component;
component cache
  port (
    rst   : in  std_logic;
    clk   : in  clk_type;
    ici   : in  icache_in_type;
    ico   : out icache_out_type;
    dci   : in  dcache_in_type;
    dco   : out dcache_out_type;
    iuo   : in  iu_out_type;
    crami : out cram_in_type;
    cramo : in  cram_out_type;
    fpuholdn : in  std_logic
end component;
component mmu_cache
  port (
    rst   : in  std_logic;
    clk   : in  clk_type;
end component;
component cp
port (
    rst    : in  std_logic;                     -- Reset
    iuclk  : in  clk_type;                      -- gated IU clock
    holdn  : in  std_logic;                     -- pipeline hold
    cpi    : in  cp_in_type;
    cpo    : out cp_out_type
end component;
component cachemem
  port (
        clk   : in  clk_type;
        crami : in  cram_in_type;
        cramo : out cram_out_type
end component;
signal ici : icache_in_type;
signal ico : icache_out_type;
signal dci : dcache_in_type;
signal dco : dcache_out_type;
signal fpui : fpu_in_type;
signal fpuo : fpu_out_type;
signal cpi, fpi : cp_in_type;
signal cpo, fpo : cp_out_type;
signal holdn, pholdn, xholdn : std_logic;
signal iuol : iu_out_type;
signal rfi : rf_in_type;                        -- register-file input
signal rfo : rf_out_type;                       -- register-file output
signal crami : cram_in_type;
signal cramo : cram_out_type;
begin
  holdn <= ico.hold and dco.hold and fpui.fpuholdn and cpo.holdn and fpo.holdn;
  pholdn <= fpui.fpuholdn and cpo.holdn and fpo.holdn;
  xholdn <= cpo.holdn and dco.hold and ico.hold;
  iuo <= iuol;
-- integer unit and register file
[B][I]  iu0 : iu  port map (rst, clk, holdn, ici, ico, dci, dco, fpui, fpuo,
        iui, iuol, rfi, rfo, cpi, cpo, fpi, fpo);[/I][/B] [B]Instantiated file[/B]
  rf0 : regfile_iu generic map (RFIMPTYPE, RABITS, RDBITS, IREGNUM)
       port map (rst, clk, clkn, rfi, rfo);
-- cache controller and memories
  cx : if not M_EN generate
    c0 : cache port map (rst, clk, ici, ico, dci, dco, iuol,
        apbi, apbo, ahbi, ahbo, ahbsi, crami, cramo, pholdn);
  end generate;
  m0 : if M_EN generate
    c0 : mmu_cache port map (rst, clk, ici, ico, dci, dco, iuol,
  end generate;
  cmem0 : cachemem port map (clk, crami, cramo);
-- serial floating-point co-processor (optional)
  fpsopt : if (FPIFTYPE = serial) generate
    fpu0 : fpu_core port map (clk, fpui, fpuo); -- Meiko/LTH serial
  end generate;
-- parallel floating-point co-processor (optional)
  fppopt : if (FPIFTYPE = parallel) generate
    fpc0 : if (FPCORE = grfpu) generate -- GR FPU/FPC
      grfpc0 : grfpc port map (rst, clk, holdn, xholdn, fpi, fpo);
    end generate;
    fp1eu0 : if (FPCORE /= grfpu) generate      -- Meiko/LTH parallel
      fp0 : fp1eu port map (rst, clk, holdn, xholdn, fpi, fpo);
    end generate;
  end generate;
  nofpc : if (FPIFTYPE /= parallel)  generate
    fpo.holdn <= '1';
    fpo.ldlock <= '0';
    fpo.ldlock <= '0';
    fpo.ccv <= '1';
  end generate;
-- co-processor (optional)
  cpopt : if CPEN generate
    cp0 : fp1eu port map (rst, clk, holdn, xholdn, cpi, cpo);
  end generate;
  nocp : if not CPEN generate
    cpo.holdn <= '1';
    cpo.ldlock <= '0';
  end generate;
end ;
iu.vhd(original file)
library IEEE;
entity iu is
   port( rst, clk, holdn : in std_logic;
[I]                     ici : out std_logic_vector (94 downto 0);
                     ico : in std_logic_vector (68 downto 0);
                     dci : out std_logic_vector (116 downto 0);
                     dco : in std_logic_vector (127 downto 0);
                    fpui : out std_logic_vector (145 downto 0);
                    fpuo : in std_logic_vector (74 downto 0);
                     iui : in std_logic_vector (66 downto 0);
                     iuo : out std_logic_vector (517 downto 0);
                     rfi : out std_logic_vector (58 downto 0);
                     rfo : in std_logic_vector (63 downto 0);
                     cpi : out std_logic_vector (392 downto 0);
                     cpo : in std_logic_vector (172 downto 0);
                     fpi : out std_logic_vector (392 downto 0);
                     fpo : in std_logic_vector (172 downto 0)[/I] showing error here in italics
end iu;
architecture SYN_verilog of iu is
   component INV_X4
      port( A : in std_logic;  ZN : out std_logic);
   end component;
   component AND4_X2
      port( A1, A2, A3, A4 : in std_logic;  ZN : out std_logic);
   end component;
   component NAND4_X2
   end component;
Re: Vsim error 3807 types do not match between component and entity for port "ici"
Its quite clear. the ICI port is a icache_in_type in the component declaration, but the iu.vhd uses std_logic_vectors. Therefore the types dont match. You need to have th same types on the component and the entity.
By the looks of the vsim load - youre using a netlist for simulation?
    V
yes i am using netlist for simulation
Your output is a verilog netlist. These only usually map to std_logic_vectors, so you need to use std_logic_vectors for the component.
