kevroy
Junior Member level 2
In my other thread, i asked how to trigger a circuit using a headphone jack. I am able to trigger using 3 NPN transistors in a darlington pair configuration (but using 3 transistors as oppposed to 2). I also have a 1 uf capacitor between the two touch points to isolate the DC coming from the headphone jack. I am able to get an LED to flash very dimly to the beat of the music, but i need to boost this somehow to trigger a 555 monostable (which i believe needs a trigger voltage to be at least 1/3 Vcc? which in my case is 5 volts).
Also, im using the audio coming out of my laptop, and i need to crank it all the way up just to get the LED to flash very dim. Is there anything i can do to fix that?
Thanks
Thanks
