voice signal processing???
ckt.R
Newbie level 3
what are the algorithims or methods that i should use in processing voice?
any books available in voice processing????? what are they???
spweda
Full Member level 3
There are several areas to study voice signal processing, such as speech coding, speech recognization, echo cancellation, speech enhancement (noise cancellation) in noise environments and so on. The general DSP theory could be used in speech processing.
swahlah
Full Member level 2
Dear ckt.R,
Speech coding related material is alll around the internet.
I am giving you few addresses and you will find different Speech coding algorithms
www.data-compression.info
www.data-compression.com
Also Try
https://www.dspexperts.com/dsp/projects/
like LPC, CELP, etc and also the thoery relted to speech coding is on the EDA Board forums like one is
Springer.Verlag.Data.Compression.The.Complete.Reference.Feb.2004.eBook-DDU.pdf
and you can find this book easily on one of the following two EDA forums, i dont actually know which one but it is in between these two
swahlah
Full Member level 2
Dear haerifar,
No this link is not expired may be you are doing something wrong because i downloaded this file today and this link is working fine
I think you should try to download this from a faster netwrok may be your session is expiring due to slow network as the file size is very big.......
-Regards
swahlah
Full Member level 2
Can anybody give me the Annexure B of G.729
-Regards
helios
Full Member level 2
Download Link: h**p://rapidshare.de/files/3019732/Digital_Processing_of_Speech_Signals__Rabiner___Schafer_1978_.rar.html
is active and i have downloaded the file !!!
purnapragna
hwy the link is still active and just now i have downloaded the file. no problem with it
regards
purna
laiza
Asia
is it more difficult than echo cancellation?
swahlah
Full Member level 2
Can anybody help me out for silence suppression.. i have to make a module for VOIP application
-Regards
