Seems weff can't be found. Are you sure that weff is a parameter which can be found in the parameter set of transistor M0 ? If not, you'd have to declare it explicitly as a parameter.
What if you substitute the -value- of Weff that you know
to be true, or that you can pick out of model / OP result
by a preceding calculator expression?
Thank you all of you for quick reply. sorry i forgot to attach screen shot. Actually i am working on gm/id method.
please point out where am i making mistake.
Regards.
Thank you for quick response. i need to plot id/(Weff) v/s gm/id OR id/(Weff/Leff) vs Vgs for this i used parametric sweep of Vgs. and tried to plot current density using calculator as shown in pic. please guide me how to plot it.
@Dominik Przyborowski, thank you for your response. you are right , i made mistake. So please tell me how to do this plot. i use 6.16 version of virtuoso. I am totally confused.
In such cases, I usually use result browser tool. From it you can easily export parameters, for example I've tried to calculate your expression for transistor N3:
But I'm not sure that "w" parameter returns Weff (anyway it's not width from parameters of transistor, in my case w = 2.4u, "w" parameter returns 2.16u).
