Re: ERROR with Configuration
Hello,
I’m not sure whether it is exactly the same error as I can’t remember exactly what is was, but I might have just come across something similar in the past. So it is a board supplied by Xilinx right. Mine occurred because it was our own board which happened to be a bit noisy i.e. some things weren’t done exactly by the bible. My magician friend was able to eliminate this strangely “random” error by applying his magic capacitor to filter out noise on certain places in the PCB. Surprisingly, depending on noise coupled by mains or even EM interference, this error used to occur randomly. Don’t know who relevant this is to you. In your case, I would suggest that there is something wrong with your boot flash as your boundary scan chain isn’t right, probably got burnt or something. Hope it helps.
Cheers.
