nic4u
Newbie level 3
hi
there is an issue
i've a virtex 5 FPGA . i m using its PCI express hard block. So, when i m powering on the CPU with the FPGA card inserted in the PCI express slot (as i m implementing a PCIe endpoint), then it will load the bitstream to configure virtex 5's PCIe endpoint n other logic....but the CPU is not recognizing the PCI endpoint.....wat cud be the reason.....
is there any timing requirements for the fpga's configuration to finish so tht motherboard can detect my PCIe endpoint device....
plz help
there is an issue
plz help
